Help: fix or part #'s... pls
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/pxl_20240709_161601622_a64090d207c6f9a652302242dcc57207405ad558.jpg)
any ideas how to either re-thread or the part #'s to reorder? TIA
Can you thread it though the hole in the rivet and knot it so it doesn't pull back through?
You should be able to find the parts microfiche on here: https://www.porscheatlantaperimeterp...car-parts.html
When I described the part to a local Porsche parts department a few months ago, they called them the "rear cargo deck cables", said they were currently out of stock, and quoted me about $16 per cable. I also searched ebay and amazon, but it seems that 3rd parties only sell the tonneau privacy cover and cables as a set, for $250 to $450. depending on condition.
So I went to the local Walmart, found a roll of thin black nylon cargo cable in their arts & crafts section, and made my own replacement cables. It took 2 attempts to get the length perfect, and I used thin pieces of metal (similar to a thick paper clip) to prevent the loops from pulling apart. I initially tried hot glue, but that did not hold, due to the weight of the cargo desk. Here is the replacement cord I purchased ($1.97 for 18-feet):
https://www.walmart.com/ip/Hello-Hob...-ft/1474175996
I hope this helps!
I hope this helps!
