Porsche Macan - Lights switch not working and lights permanently stay on
Hi all,
I've got an issue where the lights are always on. The light switch doesn't do anything no matter which position it's at. The small led above the AUTO switch does not light up. The exterior lights stay on as long as the car is running and turn off with the ignition. I assume this is also why my coming home function isn't working either. Has anyone faced this issue before? Would it be an issue with the fuse?
Does anyone know if this dial being stuck would be causing the faults with the headlights?
If the light switch needs replacing, how much should I expect to pay? I'm from London. Thanks in advance.
