After looking for 6 months, I finally found a deal in a color I wanted. A 2019 S in Chalk. Blackout package with Torque Vectoring. I had no intention of modifying the car but once I found out the support of this 3.0T engine, it was game over for me. I can't leave well enough alone.
I've ordered the following mods so far. I'm now waiting for them all to arrive to start work. 034 meth tap plate
Meth kit w/controller
BMC filter
390mm front BBK
forged carbon lip kit
Forged carbon interior
Forged carbon steering wheel
GTS Valved exhaust
Clear taillight kit
KW Coilovers
Cobb
Flat 6 stage 2+ custom tune => next phase will be a larger turbo that will be dyno tuned at Flat6 w/ Jon
Guage faces
Steering wheel paddle extension
Door & Center console speaker covers
Puddle lights
Dashcam
Rear lid control module
TGK swaybar kit w/ adj drop links
CAP rear subframe bushing inserts
CTS sport trans mount kit
JHM rear diff bushing inserts
IE high flow HPFP
Forge recirculation valve kit
Forge recirc to BOV adapter
CAP boost pipe kit
100 cel downpipe
IE Turbo inlet kit
FCP trans/diff/trans case/engine oil service kit
Spark Plug Set (2 Stages Colder) - Audi 3.0T | BKR9EIX-KT6
Nice progress. What is the donor vehicle for the brakes and will they be ok with your existing master cylinder, or are you swapping that also?
Are you keeping those wheels? I had that set and couldn't get to liking them paired with a black car but they already look better with spacers. I'm curious to see how they look with the coilovers.
I'm thinking the exterior accents would look better with the black plastic parts painted since now there's a few different textures on the exterior, but If you are good with it, that's all that matters.
I’m using Taycan front calipers, front and rear 2018 Macan Turbo rotors, and 2018 rear Macan Turbo brake caliper carriers. I’m going to run Hawk pads as I can’t stand how much dust the factory pads produce. You don’t need to upgrade the MC bc the piston sizes don’t change. They were only increased on the PCCB brakes.
I typically hate carbon but it truly works well on the Chalk color. It was hard to capture. Not everything is for everyone. The factory wheels have REALLY grown on me. I will lower it before swapping new wheels on just to see it. I want to run 21 over 20.
Nice, its great to see a cross-platform upgrade, thats one of my favorite ways to mod. I've done a similar brake upgrade on a Mercedes platform, its nice when it all just bolts together.
If you keep the wheels, I have been experimenting with different tire sizing to cut down on the sidewall bulge, weight, and improve the look and handling over the OE 20" tire sizes. I am now using a 285/40/20 Michelin PS4 from a Taycan and a generic 255/45/20 Michelin PS4S to keep the OE tire size ratios. I think the combination is fantastic for both handling and looks. Even though I have an OE forged 21" set of wheels with the smaller sidewall, the 20" wheels feel better. I think your setup will look pretty good with your current wheels but its hard to argue against 21" for their looks.
I look forward to your impressions of the larger sway bars. I installed thicker H&R bars and they were a huge improvement to the steel spring setup.
