Help - replaced indicator stalk and now multiple errors
My wife unfortunately snapped the indicator stalk and so I bought a new indicator/lights/windshieldwiper/speed control mechanism
Disconnected the battery
Took off the airbag, wheel and stalk apparatus and replaced. Hooked up all the electrics in reverse order, connected the battery and everything works beautifully in all 3 stalks and car drives fine except
Air conditioner/fan does not blow air
Errors showing
AWD fault - only RWD although when I watch the display it looks like fronts are driving as well
Headlight range regulation defective
Steering support limited - tried the fix with steering wheel at extremes and did not clear
PSM failure
I have driven about 10 miles with about 5 on off cycles and no improvement
Any ideas?
2017 Base Macan out of warranty for 3 years but no real issues
Errors showing
PSM failure
Any ideas?
Errors showing
PSM failure
Any ideas?
Errors showing
PSM failure
Any ideas?
You'll most likely need to have those errors removed (and the steering angle sensor recalibrating done) at the dealer. They may then also be able to see if the AC fan and headlight errors are related to the rest of the errors.
I just went through a similar situation when I upgraded to a heated steering wheel on my Cayenne.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_0131_c4a71666c6095a206c6224360c4a0ac527bf8234.jpeg)
