First Porsche: cpo python green 2023 gts
Hello!
first Porsche, trading in my 22 rs6. Sounds crazy but I wanted a car that could dissect canyon roads but that could also handle some rougher roads with enough space for my two dogs and I, and enough space to sleep in the rear if needed. I use my cars for cross country road trips, sometimes camping out in the middle of nowhere. This car seems to fit the bill in spades.
I do have some questions, please forgive my ignorance:
1) Is there a way to not have the radio/tuner immediately start when turning the “key”?
2) am I crazy for considering a wrap on the python green? I like to fly under the radar, definitely not possible in this color!
3) how trash are the pirelli verde all seasons? They have 11k on them, they seem to tramline on the highway. Thinking of putting on some conti dws.
4) is there any real ambient lighting besides the door pockets?
5) does this car adapt to your driving habits? I’d like a clean start and have it learn my lead foot and hoping for snappier shifts from the pdk. Is the old school battery disconnect the way to start fresh?
6) is Porsche like Audi when it comes to tuning? Considering a Cobb but I know once flashed they deny warranty without question. This car is fast enough, but wanted to improve throttle response. Ordered a roar unit so let’s see how that works.
7) I’m planning on lowering with tech art lowering module and going to add their exhaust. Any other worthwhile mods to consider?
8) does the car stay in the last driving mode you left it in? Seems my car reverts back to normal and raises the suspension.
Thank y’all and I’m excited to start my Porsche adventures!
Just one guy's .2 cents.
1) Change the source media to Jukebox or something and it won't come on each time (unless you have files loaded)
2) Python Macan's (or any Macan with a fun color in general) are fairly rare. I personally wouldn't wrap it.
6) The 2.9L GTS engine is essentially the same engine that is in many Audi products (RS5 / etc). It responds to tuning if that is your thing.
7) Can't speak for the Macan products but Techart stuff is generally trash and widely panned in the Porsche community (form over function). Most folks just add drop links if you are looking to go lower.
8) Try programming your settings to your key. Set things up how you want then press the memory button and then the key button on the driver door. It may solve that issue.
Mike981S (02-29-2024)
Hello!
Re tires, go with Michellin Ps4 summer tires if you don't drive in snow. PS4 All Season also pretty damn good but not quite as sticky as summer versions.
Driving mode always reverts back to "Normal" on restart. If you have the Sport Chrono option (rotary dial in the steering wheel) you rotate that to the mode you want. First thing I do after starting.
Air suspension position determined by two buttons on the shift panel (center console). Should stay in the position last driven in. One button left side with car icon (arow underneath) "On" (red LED lit) is the lowest position. LED off higher. Another button "Offroad" (right side) position engages highest position. Must have air suspension option (but I think all GTS versions come with this standard). Sometimes I've noticed my car changes air ride height after ign is off, but reverts back to selected position on restarting.
Ambient lighting available in overhead center console as is standard in most vehicles.Hate to add but read your owner's manual.
I have a 22 GTS. You are going to love this car if you canyon carve.
I actually tested out the space with the seats down. I can definitely sleep back there in a pinch!
Python green is awesome so yes, I would consider you crazy if you wrapped over it.
The P Verdes are trash. I'm rolling on the Scorpion Zeroes now because I have 20" wheels and there were no Michelin PS4 in that size. The Scorpions are much better.
The other source of ambient lighting is the horse shoe around the overhead buttons but I have turned off as I found it distracting even on its dimmest setting. Look in the owner's manual on how to set the brightness.
I have not seen any empirical evidence that the ECU and TCU has any adaptive learning capabilities.
Porsche dealers in the US do NOT all deny warranty without question just because you have a flash tune. Porsche is not VW/Audi. I have personally had engine and steering matters addressed fully under warranty after disclosing to my service advisor that I've tuned mine as the tune had nothing to do with those issues.
I personally would not waste money on TechArt's lowering module. If you want to go the module route in order to have the slammed show mode feature and control it via an app, check out Cete. Otherwise, Flat6 has pre-set lowering links. I got my dealer to lower mine an additional 10mm via PIWIS for free but it may not be low enough for some.
Drive mode always reverts back to economy. I suspect it's an emissions requirement. Ride height mode stays in whatever mode I had it on before but the vehicle does perform some self leveling adjustments after being turned off so it doesn't always stay in the same actual ride height.
Umm, no. We have a Golf R and the Macan is significantly larger inside. Not everyone needs an SUV the size of a Cayenne and for our use living in the city it is more than enough space.
The following 2 users liked this post by Vise:
Mike981S (02-29-2024),
WasabiPeas (02-29-2024)
Got it, those are well known issues on any 95B.1 so that's a routine warranty item. I would be wary of anything to do with power delivery although I agree that I have not read much about denials. Perhaps because the drivetrain can take the extra power and I would say from experience that those with tuned engines are more likely to be on top of care and maintenance. I don't want to lead the OP to thinking that Porsche would replace a PDK or other higher price item, or even an axle, turbo etc.. if they detected a flash tune. I personally went with a JB4 piggyback to avoid a flash trigger but more based on feel than actual evidence. I think the OP would be happy either way.
Appreciate all the responses so far!
likely going lowering links instead of any modules.
car definitely needs more sound though, exploring resonator delete options like the fabspeed. Got a bmc air filter for a bit more induction noise but the rear needs some love.
lowering links, intake/exhaust, roar peddle, Michelin ps a/s 4, and I think I’m done!
likely won’t tune it as I think the roar peddle will solve any issues since this car is faster than it has any business being.
Did the dealer expressly provide you with documentation that they would solely cover warranty claims in the event that there is a claim not covered by the factory warranty?
