Macan 2014-Current
Sponsored by: HBI Auto
First Porsche: cpo python green 2023 gts
Old Feb 29, 2024 | 11:51 AM
Dsandler's Avatar
Dsandler
Originally Posted by BMinSFL
A dealer does not fund or provide warranty coverage. The fact is that a flash tune will void your warranty, per the warranty documentation issued by PCNA.
Did the dealer expressly provide you with documentation that they would solely cover warranty claims in the event that there is a claim not covered by the factory warranty?
Thanks Porsche police. And yes my dealer did.
Old Feb 29, 2024 | 11:57 AM
BMinSFL's Avatar
BMinSFL
Lol, just trying to flush out the facts to not mislead anyone to believing that a factory warranty can be maintained with a flash tune. What your dealer is doing is not typical, as they are taking on responsibility outside of manufacturer recommendations.
Old Feb 29, 2024 | 12:00 PM
Dsandler's Avatar
Dsandler
my dealer has a performance arm and an enthusiast service manager. Plus everyone knows tuning a 2020 GTS just brings it above the power level of a 2020 turbo. Safe power
Old Feb 29, 2024 | 12:03 PM
BMinSFL's Avatar
BMinSFL
Are you referring to Champion by any chance? There's no argument about whether it is safe but PDK and other drivetrain failures happen on stock vehicles at any trim, that's my main concern for those who flash. It's not necessarily extra power that causes the issue, but stuff happens.
Old Feb 29, 2024 | 12:10 PM
Dsandler's Avatar
Dsandler
I’m in NY. I don’t uninstall the Cobb when I go for service. I do all my maintenance with the dealer not an Indy. This pdk powered the 2010-16 Panamera tt. It’s fine with the power of the 2.9 tuned
Old Feb 29, 2024 | 12:17 PM
rasetsu's Avatar
rasetsu
Got it, those are well known issues on any 95B.1 so that's a routine warranty item. I would be wary of anything to do with power delivery although I agree that I have not read much about denials. Perhaps because the drivetrain can take the extra power and I would say from experience that those with tuned engines are more likely to be on top of care and maintenance. I don't want to lead the OP to thinking that Porsche would replace a PDK or other higher price item, or even an axle, turbo etc.. if they detected a flash tune. I personally went with a JB4 piggyback to avoid a flash trigger but more based on feel than actual evidence. I think the OP would be happy either way.
No, I would never imply that one would still get warranty coverage on an issue if a tune was what caused the issue. Now that I recall, my dealer did replace my transfer case under warranty even though I had a tune so even a mechanical driveline issue was covered. Yes, that's another known issue but the fallacy I'm trying to dispel is the misconception that an entire warranty is voided by the mere existence of a tune. That is simply not true, at least not in the USA. In theory, even if a tune blows a hole in your engine but you have a window that stops working while under warranty, you can tow your car into the dealer and have them fix the window.
Personally, I believe a flash tune is healthier for the longevity of a motor than a piggyback tune. Look at some of the dyno graphs that show closer detail and you can sometimes see how the curves are smoother with flash tunes than piggyback tunes where there are more small bumps. It's almost like you can see the difference of where the ECU is doing the work without interruption versus where a piggyback tuner is intercepting and reinterpreting the signals on the fly. I think if one is really risk adverse, it's best to just leave it stock. If a motor is grenaded and diagnostic scans are ran, I would not be 100% confident that a technician is unable to see that certain parameters exceeded the factory settings. But if a piggyback tune makes you feel better, then case closed.
Do you disconnect all the wiring from your piggyback tuner every time before going to the dealer? I flash mine back to stock in 3 minutes not to hide the tune because my dealer and service advisor really do not care but only for the event that the technician has to push any ECU updates and I don't want the tuned file to cause any issues with that. Overall, it's much more involved than just tune means yes or no warranty. One has to be willing to accept responsibility if an issue truly cannot be covered due to any modification and know the dealer, and most importantly the service advisor, with whom you work with.
Old Feb 29, 2024 | 12:28 PM
rasetsu's Avatar
rasetsu
Originally Posted by hkc
Appreciate all the responses so far!
likely won’t tune it as I think the roar peddle will solve any issues since this car is faster than it has any business being.
Just drive it in sport mode and you'll get most of what drive by wire devices do with the go-pedal. Or try sitting a little further forward and adjust the amount of tip in with your foot if you think the gas pedal isn't doing what you want.
Old Feb 29, 2024 | 03:23 PM
BMinSFL's Avatar
BMinSFL
I avoid the dealer and haven't been back since installing it. Even with a warranty I would rather DIY or pay for something small at an indy shop. My last visit for free service involved them keeping the car for two weeks and returning it filthy with spiders living in it. I opted for no car wash since they are exceptionally good at installing swirl marks with their washes. If I did go, I would probably disconnect it if it was for a major drivetrain repair but not if for a small maintenance item. I am not a fan of constant flashing since it exposes the process to voltage variations which may lead to issues. I've used a JB4 for many years on various vehicles and never had any issues but I do like a full flash tune better, generally. I end up transitioning after a warranty period runs out.
7 Porsche Models That Have Aged Like Fine Wine
Old Feb 29, 2024 | 03:50 PM
rasetsu's Avatar
rasetsu
I also DIY or go to an indy for nearly all basic maintenance items but will throw a bone to my service department every now and then for items that are not much more expensive and the above-mentioned warranty covered issues to maintain a relationship with the store. My dealer is actually pretty surprisingly competitive in pricing with my local independents, they're just a bit further away. That relationship has been helpful as they offered me two PTS 911 allocations over the last year even though I didn't purchase either of my Porsches from this particular store.
I've only removed the tune 2 or 3 times plus another two times to change the fuel octane map. I do have the charging system inspected annually as the voltage fluctuations from flashing is something I'm conscious of.
Old Feb 29, 2024 | 03:59 PM
hkc's Avatar
hkc
5th Gear
Yeah I get that, it’s how I got used to my rs6. But this throttle is even worse than that and I think the roar is worth a try.
Old Feb 29, 2024 | 04:35 PM
Penstamin's Avatar
Penstamin
@hkc Re: #8 in your list, the only setting that's retained after shutdown is the auto-start-stop. Turn it off and it stays off for good. At least on my 2015 S it does.
Old Mar 1, 2024 | 01:51 AM
DHL's Avatar
DHL
appreciate the response! I figured out the ride height, thanks. Regarding the ambient lighting, that would be that overhead horseshoe and the door pocket lights? I’ve checked the manual lol
Yes. Additional lighting (map reading) is in the horseshoe above the center console. If you are looking for flash lighting strips AKA BMW X3 and Mercedes, its a Porsche and they are NA.
Old Mar 1, 2024 | 11:08 AM
BMinSFL's Avatar
BMinSFL
Good to hear. I happened to see a 2024 Cayenne loaner from my dealer on the road. Tempting.....they always find a way to reel you back in!
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
