Just bought a 2017 Macan GTS with 109k miles yesterday, couple questions
And don't forget to remove the key fob from your pocket (and place it 20 ft away from the car) when you wash it, or the water spray hitting the car will cause it to sporadically lock and unlock.
The following 2 users liked this post by DHL:
dak911 (03-20-2024),
Jaspeer7821 (02-29-2024)
The window sticker doesn’t show anything either.
I also wish this car would’ve had ventilated seats, it’s brutal here in the summer. There’s no way to add that function is there ?
There’s no dimple on my door handle. I moved my hand all over the handle and nothing happened, so I guess I don’t have it.
In order to add seat ventilation, you would have to replace the entire front seat and add the button to the center console plus likely coding. It's probably cost prohibitive unless you are willing to look for parts dismantler listings.
Penstamin (02-29-2024)
You should definitely be able to access entry into the car without using the key fob, and also lock the car from the exterior door handle without using the key fob.
I did see a little dimple hit it was dark and raining. I forgot I let my friend use the car and I’ll try it tomorrow. I’m sure it’ll work 😁
Just my opinion, mind you but "Friends don't let friends drive their Porsche". Many years ago, my "roomie" let a good friend of his run some errands in his new Porsche....He rolled and totaled it. No one but me drives my Porsches. That way, I keep my friends just that...Friends.
roll_the_dice (03-25-2024)
Jaspeer7821 (03-04-2024)
yes, always could get in the car, just didn’t know it locked without the FOB.
But it unlocks really quick when grabbing the handle to unlock.
But when locking it takes a few seconds of pushing/rubbing my finger over the indent.
doesn’t seem to lock with just one tap.
also but in new batteries in the remotes.
To unlock the car, the sensor is located on the inside (back) of the handle. The depression on the outside of the handle is for locking the car. Grabbing both - no worky...
And one more point - make sure that you are not gripping the entire handle (thereby placing your hand on both the inside of the handle, and also on the thumb depression on the outside of the handle.) It will confuse the car.
