Fractured Lifting Point
analyst
That Powerbuilt Unijack combination jack / jackstand looks like a very safe lifting method, w/ a 4K lbs capacity and a lifting range from 8-5/8" to 18-5/8".
It may be possible to arrive at a compatible interface to the Macan body.
The Unijack has a saddle top, perfect for contacting an exterior rib, like a vehicle frame, but less ideal for an internal pocket, like on the Macan.
Perhaps something like a thick wall 1" square tube cut to over 2" long might be a safe / secure / appropriate interface between the Macan lift pocket and the Unijack saddle. A quick vehicle measurement shows there is probably sufficient vertical clearance for that setup at front and rear.
Zero doubt about the setup stability.
The OP topic is about vehicle damage.
Clearly usage of lifting using a 2x4 scrap across the Macan jack pocket results in vehicle damage.
Switching from a 2x4 board across the jack pocket to an appropriately sized device inserted into the pocket, or a device specifically designed for the pocket, should prevent damage to the vehicle.
These Pelican images show that pocket and the concealed lifting point.
As was stated my vehicle has been lifted many times by me, at the lifting pockets, using appropriately sized inserts, w/ zero vehicle damage.
Why not post images showing the jack point pockets, damaged by lifting w/ a 2x4 board interface?
![](https://live.staticflickr.com/65535/53531386778_8c6407fbdb_c.jpg)
Yes, I would also expect that saddle to damage the vehicle w/o using something to spread the load force.
Continued usage of fresh 2x4 scraps, so that the Unijack saddle digs into the wood, should be an acceptable interface for strength and stability.
Alternately, usage of a ~2" long thick wall 1" square thick-walled steel tube should also be a good permanent interface between the Unijack and the Macan rocker panel jack point lift pocket.
ECS Tuning says no longer available but maybe they can found elsewhere
https://www.ecstuning.com/b-genuine-...d-kit/mk4jppk/
EDIT:
Found this:
audi TT 8N support lift for sale | eBay
And this:
Lift Pad Set (A4) 8N0804583/8N0803855 | IDParts.com - Diesel Parts
EDIT:
Found this:
And this:
wingless (02-19-2024)
analyst
EDIT:
Found this:
And this:
EDIT:
Found this:
And this:
Is there sufficient clearance for those to remain permanently installed and the the underbody cover installed w/ those pads remaining in place, at all locations?
