Macan 2014-Current
Sponsored by: HBI Auto
Brake flush
Old Dec 9, 2023 | 01:36 PM
dak911's Avatar
dak911
Default Brake flush
How often is it really necessary to flush the brake fluid?
Unless you are using your MACAN as a track car, or are extremely hard on the brakes
Years ago I don't think flushing was as common, they got flushed when new pads were installed.
Old Dec 9, 2023 | 01:39 PM
Bxstr's Avatar
Bxstr
Porsche recommends every two years. My dealer charges $200, so it's easy enough to just follow the recommendations which is what I do. If you want to test it prior to replacing, get one of these and it'll tell you.
Amazon Amazon
Many factors contribute to how frequently you need to flush your brakes, climate and humidity being one of them, mileage, time, etc.
I have plenty of friends that never flush brakes on their daily drivers and they're fine.
Old Dec 9, 2023 | 03:25 PM
dak911's Avatar
dak911
Gonna' get me one o dem tester thingys...
You can NEVER have too many tools and gadgets if you are a true P car aficionado
Old Dec 9, 2023 | 08:53 PM
DBH's Avatar
DBH
It's like tires, you always want them in tip-top shape.
Old Dec 9, 2023 | 11:00 PM
chassis's Avatar
chassis
It's a German car thing. MB, BMW and Porsche call for brake fluid flush every two years. You would be surprised to see the crud and bubbles you can see emerging during the process.
Old Dec 9, 2023 | 11:08 PM
Ironman88's Avatar
Ironman88
Brake fluid is hygroscopic. It attracts moisture. Moisture in your brake fluid can and does result in corrosion within the braking system.
Porsche braking system = $$$$$
Changing your brake fluid every two years is a good policy.
Old Dec 9, 2023 | 11:55 PM
Nickshu's Avatar
Nickshu
+1 for a brake fluid tester.
Old Dec 10, 2023 | 02:29 AM
#1SomeGuy's Avatar
#1SomeGuy
It's also a sealed system, so no moisture should be getting in there. Having tested fluid in vehicles after 5+ years with zero or 1% readings at that age, I really think it's a little over aggressive the Porsche schedule...or at very least they should inspect it and only change as necessary.
7 Porsche Models That Have Aged Like Fine Wine
Old Dec 10, 2023 | 08:57 AM
nevil's Avatar
nevil
It's not limited to certain makes of cars. Even my Harley service manual recommends a brake flush every two years. It's good practice for all vehicles.
Old Dec 10, 2023 | 10:48 AM
dak911's Avatar
dak911
Testing sounds like a good idea, why be wasteful and discard it if its not contaminated?
Old Dec 10, 2023 | 11:06 AM
Ironman88's Avatar
Ironman88
Old Dec 10, 2023 | 11:38 AM
misteralz's Avatar
misteralz
Twenty years ago - or probably longer, tbh - you'd've been doing a full fluid change bit by bit over the course of two years as you replaced sticky calipers, split or bulged hoses, or rusty bleed nipples. Cars are built to last longer now and are also built from better materials. You could, hypothetically, go ten years without touching a bleed nipple. Which pretty much guarantees it'll be stuck solid in the caliper. Cracking them every two years and pushing 250mL of brake fluid through is good preventative maintenance.
Old Dec 10, 2023 | 02:41 PM
DBH's Avatar
DBH
I was under the impression that the brake system had a vent and thus not fully sealed.
Old Dec 10, 2023 | 02:48 PM
chassis's Avatar
chassis
The system is sealed until the moment the reservoir cap is removed.
Old Dec 10, 2023 | 07:01 PM
sctw's Avatar
sctw
Actually just had this done yesterday along with the PDK flush, which is recommended every 4 years. Around $800 with local tech. Only 20k miles on my '20 S but now that it's out of warranty don't mind spending the $ on yearly maintenance to avoid any major issues down the road. Plan to keep my Macan for another 4-5 years so.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
