Macan 2014-Current
Sponsored by: HBI Auto
Brake flush
Old Dec 15, 2023 | 07:01 PM
DHL's Avatar
DHL
Originally Posted by #1SomeGuy
It's also a sealed system, so no moisture should be getting in there. Having tested fluid in vehicles after 5+ years with zero or 1% readings at that age, I really think it's a little over aggressive the Porsche schedule...or at very least they should inspect it and only change as necessary.
Moisture gets in a "sealed" system via diffusion through rubber brake lines and seals, so even a brake system is not hermetically sealed. Even small amounts of moisture can drastically effect the boiling point of brake fluid, which is the real issue. If you track the car this is more important than if you do not, or brake from high speeds.
