Any experience with COBB Accessport for Porsche Macan (95B.2/.3) S / GTS / Turbo
I was wondering if I can install this on my 2023 Macan S without any warranty issues. Are there any experiences here with this system and is it worth the $1500? Thank you in advance!
There is also the APR+ option which is a flash tune but you have a separate drivetrain warranty from APR to replace the voided Porche one should you need a drivetrain repair.
It is a 5-minute process to remove the Cobb information before you take it into a dealer. Same again when you put it back on. Also consider installing a Pedal Commander.
You're driving along... Everything seems to be going okay. Then for no obvious reason, the Porsche dies and you're not close to home. Assuming the vehicle can still operate and it's still running or can be restarted without hearing strange noises coming form under the hood, do you still have the ability to un-flash it before the flatbed shows up to take it to the dealership of choice? Or possibly a different one based on where you broke down?
To answer the OP's original question: It voids the warranty if they find you have flashed the ECU. Same goes for the TCU should you mess with the PDK.
john981 (10-28-2023)
And as someone said you can always remove Cobb tune anytime
I was thinking about installing Cobb on Macan S but car is only a few months old so will wait a bit. It will never be like my Cayenne turbo even with the tune (especially mid range acceleration)....but the Cobb is still a conservative tune which may do the trick for higher-end power bump (more noticeable on highways in my view)
I did this tune roughly at 2500 miles into my MY23S. I had a break-in oil change done at 1k after driving it conservatively. So far it's been a blast. Turbo whines faster and there's not much of a lag in acceleration anymore. Car is a bit sportier, but as always - it eats gas like it's drinking water.
