3 beeps from rear speakers.
Hi all,
Yesterday I started having two issues, possibly related.
1. The rear hatch of my 2015 Macan S randomly opens when the car is unlocked. Even when car runs (stationary) it sometimes open. If I lock it, it no longer opens.
2. While driving, at no particular speeds (happened at 15,20,32, etc.), and unrelated to the set speed limits (first thing I checked) are these 3 beeps. Does anyone know what this means? It's not a blind angle sensor, no lane departure, nothing that obvious. And they come from the left rear speaker.
I'll probably figure out 1. once I get it checked, but maybe someone here knows what those sounds mean.
I can't attach the video but here's a yt link - https://youtube.com/shorts/YB_ERDNR_IQ
Any help would be much appreciated.
Cheers
Cheers
Hi all,
Cheers
Cheers
Overnight I locked the car and removed the batteries from the key to exclude a faulty key.
This morning, the car's battery was drained and I had to jump-start it.
Yesterday evening I noticed a clicking sound coming from the trunk / gas tank inlet. As if someone was trying to unlock/open the trunk or pressing the read windshield trunk button.
Could it be a short-circuit on that button? It wouldn't open the car when it's locked and the key isn't near and I guess it could drain the battery?
Or could it be just a dead battery that needs replacing?
One more weird thing I noticed, the 3 beeps don't come from the rear speaker, but somehow from inside the trunk's door, from under the plastic casing.
I guess it is also possible you have a weak battery and that is causing the issues you are seeing. These cars are very sensitive to weak batteries and they can cause a miriad of problems. Put a charger on the battery and make sure its fully charged. If a fully charged battery is running down overnight then there is probably something else wrong. If the problems go away then I would consider replacing the battery or at least put a battery maintainer on the car overnight.
Ok so I had it scanned and there's an error with the trunk actuator. It looks like it's depressed.
Also I found what that sound was - it's as if I'm pressing the trunk open button on the driver door panel while driving - if driving the trunk obviously won't open, but that sound comes on.
Good luck getting it resolved quickly.
