Best upgrades/mods/accessories
dak911 (08-10-2023)
This is nice to block out the sun since the visor is too short:
Also this is my preferred phone holder/charger. Works on Android too if you add a magsafe ring to your case or phone back:
https://nine-volt.com/collections/al...r-apple-iphone
A silicone license plate frame helps clean up the rear end and keep everything scratch free:
https://a.co/d/cfsxsgl
Finally, I would recommend placing PPF on the exterior cameras:
https://rennlist.com/forums/porsche-...n-cameras.html
Akebono pads are only available for the front and rear Base brakes (up to 2021 I think). The Macan Base brakes (Brembo 4-piston front) are the same as some versions used on the 2009 to 2017 Audi Q5.
I suspect that there is an Akebono pad that fits the larger Brembo 6-piston front calipers used on the V6 Macans.....that caliper is not a unique design for the Macan.
Akebono omits pad fitting info for Porsche vehicles, probably because they have some agreement for that, due to them being an OEM supplier to Porsche.
boyce89976 (08-12-2023)
Please post what you find. I didn't think any vehicle would have worse brake dust than my '14 X5, but wow, the Macan is close if not worse, haha!
Many mods…most cosmetic. First, puddle lights. Then, checkered Coco Mats. Black ignition dummy key. MagSafe phone charger/mount and Porsche logo cup holder coasters. Then, tri-color key fob case from AliExpress.
Also installed Pedal Commander (a terrific “performance” mod) and door handle pocket inserts (also from AliExpress).
