Some Advice on Purchasing a Pre-Owned Macan...
Hey there - just now a month into our nice pre-owned 2018 Macan GTS. Loving it and getting used to it's size, speed etc... Overall happy with purchase.
Took it into my local Porsche dealership yesterday for a good inspection and discovered it's got a Pre-owned Warranty that's good until Jan 2025! SCORE!
On inspection:
1. BRAKES: A bit mushy and not super stoppy. Disocover after market rotars and pads (??) that need replacing, fluid is dark and needs flushing (Not covered by Ext. warranty)
2. SUSPENSION: Right AS sensor needing replaced (Covered by Ext. warranty)
3. INTERIOR: Dashboard leather liffting up (Covered by Ext. warranty)
4. ENGINE: Oil leak - valve cover gasket? (Covered by Ext. warranty)
5. TIRES: Very good
6. WINDSHIELD: needs replacing (Not covered by Ext. warranty - GEICO insurance may cover it.)
Parts for AS, dash etc... all order - 4 weeks for delivery.
Bottom line? My friend did an excellent job on pre-inspection. Official PPI discovered numerous things, most covered by Ext Warranty. Whew. Super fortunate to discover it has the remaider of Ext. Warranty to cover these.
Looking at out of pocket about $3800* for brakes and +/- $1800 for winshield (IF Geico does not cover it). I'm OK with this.
ADVICE FOR THOSE PURCHASING A PRE-OWNED
1. Know before you go - have it taken to a Porsche Dealership and get a good PPI, scan the VIN for any pre-owned warranty. It might cost you $500 but I think looking back it's money well spent.
2. Enquire has to any remaining Pre-owned Warranty - I was SUPER lucky on this.
3. If not purchase an Extended Warranty as stuff can happen on these cars.
Just my 2 cents worth.
Again, happy with purchase as she's fun to drive but eyes open as to her needs.
JP
P.s. Porsche Clearwater, FL, service department? EXCELLENT. 5-stars.
* Correction
On inspection:
5. TIRES: Very good
JP
* Correction
That's why I recommend that at a minimum you buy a CPO Macan to avoid all this BS and gives you the peace of mind to buy and enjoy the vehicle until such time as you get to know what maintenance is needed. A lot of your list would have been covered in a CPO inspection.
$5K for brakes? Are they replacing the calipers? Rotors and pads should be $1500 or less. I shopped mine around to different indies and was quoted anywhere from $1400 to 3000. 2018 S. Parts can even be bought for $600 online for everything but I’d probably screw up the install if I did it myself.
The following 3 users liked this post by john981:
You open the cap of the brake fluid reservoir only, and make sure it does not overflow when the pistons are pressed back in.
FRUNKenstein (08-13-2023)
Pre-owned 2017 Macan
On inspection:
5. TIRES: Very good
JP
* Correction
On inspection:
5. TIRES: Very good
JP
* Correction
Your post had me scratching my head a bit…meaning all of the items you mentioned that the dealership found, does the Porsche in all its intelligence not tell you these things needed attention? I owned a 2011 BMW in the past and always found some solace in the fact that it always let me know when something needed maintenance and/or something was needing repair (via a plethora of indicator lights). I guess I assumed that Porsche, in all its German fineness would do the same. Now I’m nervous! I know, I know I need to read the manual…which is on my to-do list!
Excellent news on your warranty! I’m definitely going to check that out for mine so thank for the tip!
Hi… new owner of 2017 Porsche Macan. I’ve only had her about 3 weeks. I’ve also never owned a Porsche before at all. So I’m a total newbie.
PorSHErookie (08-14-2023)
