Macan 2014-Current
Gasoline for 2023 S in US
Old 08-21-2023, 07:34 PM
Russian Mafia
Russian Mafia's Avatar
Originally Posted by tangerine_sky
False, your statement is only correct for naturally aspirated engines.
For forced induction engines:
  • cylinder pressure is the same regardless of altitude
    • aside from the slightly higher RPM required to achieve the same cylinder pressure due to decreased compressor efficiency compressing lower density air at altitude
    • intake air temperature will be higher at altitude due to the compressor having to spin at a higher RPM to achieve the same charge side air density
So, you are actually at a higher risk of detention because air going into the engine will be hotter at altitude.
Interesting. I don’t have your level of knowledge I was basing it on PCA people here.
Old 08-23-2023, 07:51 AM
dak911
dak911's Avatar
I'm thinking that only the HEAVY foot people "may" have a problem with 90 or 91...
Old 08-23-2023, 08:22 AM
WillyDaP
WillyDaP's Avatar
Recommendation is the same for a multitude of Performance cars and the answer has been the same from all the Manufacturers I sold, 91 is perfectly fine and the 93 Octane is what was used to meet the max HP rating. Not sure why folks are still wondering about whether it is an Ethanol mix, that has not been an issue for any make for Decades.
Quick Reply: Gasoline for 2023 S in US
