My C-Tek 40-206 MXS 5.0 just arrived today from Amazon. I plan to use it to charge my 2023 Macan S.
I am currently using a Porsche Charge-O-Mat to charge my 991.1. The Porsche charger is suppose to be able to self select AGM vs regular mode. I noticed the CTEK will need the user to select regular vs AGM mode. I believe my 2023 Macan uses AGM but not 100% sure. What will happen if I select the wrong charge mode? A quick google search says it will cause damage to the AGM battery or even explosion! Now I am worried…
I would not be in favor of a device that must be hooked to the battery but browsing Amazon I see the CTEK 56-870 which is alleged to work through the cigarette lighter. It has some glowing reviews and I wonder if anyone here has and uses one.
I’ve owned and driven various Porsches since the sixties. In 1988 I visited the factory to pick up my special order 928. Then as needs changed I had several Cayennes and then some Audi Q5s.
Now I have acquired a 2017 Macan Base and having passed 80 (years, not MPH) I don’t drive it all that much.
In about 1988 I bought the battery maintainer pictured below for use with my 928. There seems to be some confusion so I’d like current (no pun intended) advice on whether and how often I should use it now with my Macan, which is kept in a detached garage, neither heated nor air conditioned here in Oklahoma.
TIA,
—Bob
I still use this classic battery maintainer for our 2008 Cayman. I have a CTEK for the 991 (AGM mode-snowflake symbol) and the Porsche Classic charger for our old 911, but there is something cool about this one.
--Bob
I use my 40-206 through the auxiliary cigarette lighter in the foot well of my Spyder and it works flawlessly
If you use an AGM charger on a "flooded" lead-acid battery it will slightly overcharge it.
If you use a flooded lead-acid charger on an AGM battery, it will slightly undercharge it.
Nothing is going to explode.....
