Premium Octane?
Apologies. I’m in Texas. 93 is readily available. Only the best for mine.
You don't mention which model Macan "SHE" drives. Porsche recommends that I use 93 octane in my '22 GTS. As a minimum, they recommend 90 octane as an "Alternate fuel". Not sure what Porsche recommends for the base and S models.
I drove to Phoenix a couple months ago and 93 starts to get pretty scarce the farther west you go. There are 2 websites dedicated to finding 93 so I mapped it out before leaving and did find stations in Tulsa, OKC, Alb and Amarillo. In Phx there is no 93 so I called a dealership and the service rep said it's perfectly fine to use 91...and Porsches are everywhere out there. He did say several places sell "racing fuel" 100+ octane that some drivers mix with 91 but I just used straight 91. I did wonder if he said 91's fine because that's all they have.
https://find93.com/
https://www.zeemaps.com/mobile?group=1385950
https://find93.com/
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
Not a single station where I used to get 93 can explain why no more, and when is 93 coming back.
Most gas stations get gas from whatever refineries produce the same gas. The differences are additives and in some areas, how much ethanol is added. Otherwise, it really doesn't seem to matter.
Note that at higher altitudes, e.g. 5000+ ft, you can get away with lower octane fuel. At 7000 ft, I had no issues with 89 octane gasoline and never detected any knocking or other issues. This is probably considered heresy by some, but it worked fine for me.
for california peeps, you can kind of get 93 by mixing 100 and 91 at the same station.
7.8 gals of 91oct
and 2.2 of 100 will give you 93.
this is a 10 gallon ratio.
all up to how you see it. in nor cal there are a couple of 100OCT stations.
7.8 gals of 91oct
