Air Suspension vs coil
Hi,
it depends if you think you will ever need air suspension.
I have a Cayenne with air suspension but in 2+ years ive never adjusted the ride height once.
Recently bought a Macan and was definitely looking for one without air suspension.
My rational was that it is a super expensive fix if it goes wrong or needs servicing compared to regular suspension. Plus it adds unnecessary weight and it must affect handling.
The standard coil spring suspension is very comfortable and see no reason to upgrade to the air suspension. The only advantage I see for the air suspension is that it allows you to lower the ride height and makes the car look better, but definitely not worth paying whatever it cost just for that 1 feature.
I have had air suspension in both Macan S vehicles I have owned (2017 and now 2022) so don’t have a personal point of comparison on the Macan S. However, having owned many vehicles with and withou air suspension, I have, with one exception (2020 Mercedes GLC AMG43 which, while it had a form of air suspension, had a harsh ride) found air suspension to improve the quality of ride on rough surfaces and handling in curves. Before both Macan purchases, I watched many Macan S online reviews and the professional reviewers consistently praised the ride and control from air suspension. With my new 2022 Macan S, I am amazed at how comfortable the ride is over road surface imperfections and the control in cornering. there are many expensive components on the vehicle, including the air suspension, so, I plan on buying an extended warranty if I keep the car past 4 years.
On the other side, I regularly get loaner Macans without air. There is no comparison.
In terms of ride comfort, I think the air suspension gets a lot of credit that more properly is due to PASM. Get that for sure.
My short test drive confirmed that I couldn't really tell the difference between PASM+AS and PASM+steel, except possibly on speed bumps in parking lots.
Originally Posted by mikegally
Hi,
I have a Cayenne with air suspension but in 2+ years ive never used it once.
My '15 S had PASM and coils. My '18 Turbo has PASM and Air Springs. The Air Springs are marginally more supple, but the S was plenty supple.
Handling was about equal - unless driving in the lowered setting in the Turbo, where the lowered CG is noticeable. But frankly, it could be psychological as I have another toy for handling tasks.
Thank you for all the inputs. It looks like the consensus is that air suspension is better, but can cost more to maintain. In looking at the 4 cyl models, it appears that the 2018 sport edition is the most prevalent with AS. I have not found many at all in 2019 or above with AS. Thanks, again to all inputs.
Expensive to repair, but well worth it as even a short test drive will confirm. My prior experience: Parent's '59 Citröen ID19, then driving a friend's 2CV about 60 miles like a 19 year old would while in college in France, my own '70 MB 300SEL 6.3.
