Navigation map online update
Hi All, driving a 2019 Macan S in Montreal Canada with an active subscription for navigation.
There has been no updates available to download.
Would anyone be able to share what’s the latest version of the navigation map ?
Currently mine is at 2018. And my dealership told me it’s the latest.
Secondly has anyone been able to update over the air via wifi ?
Porsche helpdesk told me it can only be done via sim.
Thirdly the dealership told me if there is an update and I would like to update manually - it would cost $400-500 as they would have to order the media.
How much are you paying for a manual update at the dealership ?
Thanks in advance.
Thanks in advance.
Registered User
I use nav vis my iphone via apple car play so I don't really worry abut older maps in my PCM.
If you don't have apple car play and still want the updated PCNM maps, search this forum for simaservis1108 - he has been able to download map updates and as well as activating apple carplay and android auto
I haven't been able to get OTA map updates ever working well. Dozens of phone calls to Porsches, multiple cases opened, and a trip or two to the dealer to try manually updating with a DVD and nothing. I only renewed the free one year one time and then asked for a refund after months of no working.
Also, for more than a year, my Apple calendar will not synch with the car.
The techs at the dealer say there are all sorts of problems with OTA map and other PCM issues.
I am using car play exclusively now, and that's a shame because I liked the PCM nav much better.
Travelled to NY today - nothing.
And then porsche connect started working after I reconfigured the TCPIP config on my phone - FYI.
Remove the default route and the auto DNS assignments when you hotspot to the car for connect …
But today
Just 2 days ago - rebooted the PCM for kicks and suddenly I received an update notification - 878mb of the map for download. Now its decided to label the version of the Navi map NAR 2022. But when I looked at the specifics - only the state I am in is updated. All other states still 2018.
But today
But today
Can you explain the TCP/IP?
That was my problem with the maps. Alabama was always a believable date and sometimes Florida. But every other state around me regardless of how many times I drove through them were at least 1-2 years old. They could never tell me why or what each individual state's version number should be. I got so fed up with them. I told them I was their easiest sale and it didn't motivate them.
Then turn on your iPhone’s hotspot on and make a connection from your car to you phone.
It will use your phone’s data plan but this got everything working …
I use an iPhone … setup the car’s hotspot. Then get into the iPhone wifi and search for the car’s hotspot. After connecting - get into the profile of that connection and write down the IP address. Then set it for manual IP and use what you wrote and leave the router blank. For the DNS - set it to manual and use the IP address of your ISP.
2. Do you have to use your phone as the wi-fi hotspot from then on? I have the AT&T car hot spot subscription for $15/month and it works great for other passengers in the car and complements my phone's T-Mobil so we are very rarely without internet in just about every place we have been.
Thanks!
1. How do you find the IP address of your ISP?
Thanks!
Thanks!
2. I had a problem with Bell so I had to use my phone as a hot spot.
