Battery Tender
I can highly recommend Battery Tender brand maintainers. I've used them for many years on BMW's, Volvo's and Porsches. I haven't had the opportunity of using the Battery Tender on my '22 Macan GTS as yet. I guess I'll have to experiment the best way to attach the unit...12-volt receptacle or alligator clips to the +/- posts. I've done both, successfully, in the past. I'd be interested if anyone has determined if the 12-volt receptacle on the center console remains "hot" after the ignition is turned off.
The center console 12v port remains hot only if you plug in the charger within a few seconds after you shut ACC off on the ignition. So long as something is consistently connected, it stays hot indefinitely. But if the charger loses power for a bit, the port goes back to sleep. This was how it was on the gen 1 Macans. Don't know if they've revised it on gen 2 to be like the 911 and Cayman/Boxsters where it stays hot all the time.
If I understand this correctly if you leave town for an extended period with the maintainer hooked up through the center console 12v, any interruption in power will shut down the maintainer so you could be in for a surprise when you return home. Is that still true? I've always used the jump terminals under the hood.
I had to look this up and eh...we both may be wrong. https://carbuzz.com/cars/porsche/macan-generations
- As long as there is power provided to the center console cigar lighter port, applied within a few minutes of shutting off the vehicle key, it will allow charging indefinitely.
- If power is interrupted to the charger for more than a couple of minutes, the center console port will time out and go inactive, after which the charger cannot resume charging when AC power is restored.
I use the center console port for routine during the week charging (I can see the charger lights to confirm it is working whenever I enter the garage). For longer term if I am going to be away from home, I will use the under-hood terminals. If you have the Porsche-branded CTEK with the permanently attached cigar lighter plug, they sell an adapter that you plug that into to adapt to alligator clips. Oh, and I put the Macan on the charger anytime it is in the garage, even just overnight. I've always done this and my batteries seem to last for many years.
