Macan 2014-Current
Sponsored by: HBI Auto
CEL, check control module after changing spark plugs
Old Aug 21, 2021 | 10:05 PM
Irfan's Avatar
Irfan
Default CEL, check control module after changing spark plugs
Got CEL, check control module after changing spark plugs. Not sure what’s causing the CEL. OE plugs and checked gap prior to install and torqued per spec. Any suggestions?
Old Aug 24, 2021 | 12:13 PM
///Bruce's Avatar
///Bruce
I'm reading into this that the Porsche started. Also, that there was no shuddering/shaking. Question: did you do one plug at a time? What I'm alluding to, is you might have mixed up two of the spark plug ignitors. Each one is set to a particular cylinder. If that was not the case, double check all your work. Look to ensure everything has been properly reconnected.
Old Aug 26, 2021 | 10:28 AM
Irfan's Avatar
Irfan
Yes one plug at a time. It ended up being broken plug on cyl 6. All good now.
Old Aug 26, 2021 | 11:01 AM
///Bruce's Avatar
///Bruce
Glad you found it. Enjoy.
