Adding 1 quart of oil between service?
My 2015 Macan S warned to add 1 quart oil before service, which is due in about 6 months. It has 65K miles on it, and it never happened before. Is this kind of normal? Any ideas???
Thanks,
Thanks,
how's your timing chain covers? Any leaks?
Only time I had to add oil between changes (car has 140,000 miles and oil changes every 7.5-10k miles) was when I had a leak. It was at the oil filter housing. I was not yet aware that the o ring required on the Macan was bigger than the one that comes with the mahle filter.
