Three Zone Climate Control
I apologize in advance for this basic Q... I am curious to understand if the Fan speed can be adjusted separately for the driver and passenger. IE: Driver Fan set @ 5 , Passenger speed set @ 2.
Cut from Standard features section:
- 3-zone climate control with separate settings for driver, front passenger, and rear passengers
So for clarity is the answer yes you can have different fan speeds for the driver and passenger ? I have no access to a P vehicle nor have I owned one in the past ....Mine arrives in Sept 2020
Not sure about the back seat settings but as long as sync is not engaged, as stated above already, the temperatures and fan speeds can be set differently for the driver and front passenger. These can also be tied into the preset as well as a specific key. The "auto" key defaults to 72 F and I believe 3 for the fan speed. Much of this is outlined in the owner's manual.
