2020 Macan (2.0 liter engine) Oil Viscosity
I noticed that the owner's manual for my wife's 2020 Macan with the 2.0l engine calls for 0W-20 weight oil. Yikes -- that seems too thin to me, especially for use in a direct injection engine that is subject to low speed pre ignition.
My guess is that the thin 0w-20 oil helps meet Porsche's published gas mileage figures, but that's only a guess. What weight oil are other folks using in a 2020 Macan with a 2.0l engine? Also, what is the engine oil capacity?
Thanks!
Jason
Thanks!
Jason
I don't understand the 0w-20 recommendation. It seems to be driven by the need for better gas mileage or perhaps there's some environmental factor at play here, but I can't imagine what it might be.
Notably, the Mobil 1 website calls for FS 0w-40 for a 2019 Macan with 2.0l engine. Is there any difference between a 2019 and a 2020 Macan engine? I doubt it. So what changed?
Jason
Yes, I live in Houston, Texas where the temperature rarely dips down to or below freezing.
Jason
Jason
Jason
Jason
I had a 2017 with the 2.0 and the dealership used the C20 spec oil. I promptly changed it out for Driven DI40, but I lost at least 10% fuel economy (maybe more) going to the 40 wt. The wear levels were near zero with the DI40, so at least I know the engine was healthy!
Jason
Jason
Well, I just noticed that someone on Maycanforum.com, commented that the 2019 2.0l Macan takes approximately 5.5 quarts of engine oil.
And I think the 2019 and the 2020 2.0l engines are the same, so I will revise my oil-on-hand requirement to 6 quarts.
Jason
Jason
Sorry, I don't recall the article that claimed 8 liters, which would admittedly be a lot for a 4-cyl engine! My XK-E took 9 quarts, but it was over twice that displacement. The engines are slightly different but I would be surprised there's that much of a difference in oil capacity been th e2018 and 2019 model. I could be wrong and have been wrong about many things, many times before ...
