Can "Hold" function be disabled?
Acquired a '15 Macan S last fall. The brake "hold" activates often on level ground, when not purposely initiated and thus unexpected. I've RTM, and had dealer check it out. I'm told that it must be me, inadvertently putting pressure on the brake as my RF goes to accelerator and the system reads that as a Hold request. IF that's really the way it should work, that sensitive, I'd rather turn it off. I've had decades of practice with up- & down- hill starts with a clutch, for heaven's sake.
Working properly, it’s not all that sensitive. It takes an authoritative “pump” to activate on level ground. I use it a lot at stoplights and such where I can then put my right foot back over the accelerator and get an even quicker jump when ready to roll. I love it. And as mentioned, it’s pretty seamless when wanting to go forward. No lurching, no hesitation. The smallest actuation of the accelerator gets you rolling. I’ve used this function as an advantage and never a detriment.
ottobon100 (07-12-2019)
Or, YOU are initiating it when you lift your foot off the brake pedal in order to go to the accelerator pedal by pressing
a fraction of a second before you lift.
Think about it - try to observe closely what it is that YOU are doing to activate the Hold function.
I actually like the hold feature, but if it were triggering on level ground it would annoy me too. In my opinion, it takes a fair amount of extra brake pedal pressure to trigger it when not on an incline. Okay, maybe it's just because you have a lead foot - but then again maybe not and something needs to be adjusted. I'd let someone else drive the car and see if they experience it frequently engaging on level ground as well.
