Steering Feel/Weight
Thinking about trading my 14 Cayenne GTS in for a Macan but wanted to get some input from owners. I have a base Macan loaner right now and I’m finding the steering to be a bit odd...almost feels like it has some elasticity in it. The first 5 or so degrees I turn the steering wheel, it’s easy and there is not much wheel movement...keep turning and then it gets artificially heavy and the wheels turn more linearly. Do the GTS and Turbo models feel the same? The steering on my Cayenne feels much more direct and quick in comparison.
The steering on my Macan GTS feels every bit as responsive and direct as my Cayenne Turbo did, if not more so.
i own a 2018 turbo and have experienced what you’re describing. i had it serviced recently for two warranty issues, one of which was the known steering wheel groan. my macan had the updated steering column, so the service bulletin called for lube and friction tape. when i picked up the vehicle, the groan had dissipated but the steering sensation you desrcribed seemed more pronounced. i plan to drive it a bit before deciding on a return visit to the dealership.
overall, the macan steering seems a bit too light and not as linear, especially at center, as a vehicle at this level should deliver. it’s very possible carguy’s point about power steering plus is accurate, as my macan does not have this feature.
