Clear front side markers
Drcollie,
I bought the same set on eBay, but the plugs seem to be different. The OEM has a block style plug and the eBay one has the same as your showing with that purple object in it. Did you have to slice anything or modify in order for it to fit? Any input is much appreciated.
Thanks!
Thanks!
I'm going to order from Flat 6 Motorsports, but since my car is white should I keep the white bulb in there or switch to the ugly orange bulb that comes with the kit?
https://flat6motorsports.com/product...31290308165716
Help with removing the light?
I opened up the fender liner but still puzzled with what and how to push.
I presume there is a spring clip that must be pushed forward (toward the front of the car)?
TIA, Phil
TIA, Phil
1. It is setup that above 43mph (or thereabouts) the height increases for added comfort
2. Not harsh at all, I would describe it as firmer and more sporty, but wouldn't at all call it harsh (in a kidney jarring way) I have been largely driving it from the out-of-the-box setup and I find it just perfect, played a bit with the settings (even just for the heck of it giving the Macan a 'gasser' look LOL, so the ride gets noticeably firmer [less suspension travel] as you drop it to the extreme, naturally)
One of the immediate distinctions from a feel perspective is the noticeable decrease in body roll (e.g. taking spirited turns over uneven pavement). A lot more controlled, composed, and planted now, which makes sense given lower COG.
