Macan 2014-Current
Clear front side markers
Old 06-01-2019, 10:04 PM
  #46
///Bruce
///Bruce's Avatar
Originally Posted by Van Larson
Here you folks go! Easy, peazy, great fit/oem quality. Pleased.
What about the connectors? Mine do not match at all. You cut the wiring? The OEM lights have bulbs. These have what looks like LED strips. The connectors are WAY different. What did you do?
Old 06-01-2019, 11:13 PM
  #47
slimcharles
5th Gear
slimcharles's Avatar
Originally Posted by Stack24
With no real options that I liked that were simple enough I went the Lamin-X route as well. I think it works well with a White GTS since it has black accents. It also comes with the rear reflectors for the bottom if you choose to install those. Completely changes the look in my opinion.
Before
After
Left Side - Tinted Right Side - Original
Hey man which rims are those?
Old 06-02-2019, 08:12 AM
  #48
Van Larson
Van Larson's Avatar
Insert male pigtail connector into bulb holder female receptacle after removing (pull out, no twist), stock bulb.
Old 06-02-2019, 08:54 AM
  #49
CarGuyNVA
CarGuyNVA's Avatar
Those are the OEM GTS-only 20” Spyder RS rims in Satin Black.
Old 06-02-2019, 09:42 AM
  #50
blacksheepSpyder
blacksheepSpyder's Avatar
They aren't GTS only, I have them on my S
Old 06-02-2019, 10:40 AM
  #51
Willy07
Willy07's Avatar
Looks good man....glad I went tinted....shoud be here this week......
Old 06-02-2019, 07:15 PM
  #52
///Bruce
///Bruce's Avatar
I got both in. Unfortunately, the driver side does not light. I'm afraid of breaking the sucker getting it back out. Question: do you need to press really hard? Or should it be done gently? The retaining clips seems to be of strong material.
Old 06-02-2019, 10:21 PM
  #53
81911
81911's Avatar
Yes they are. Unless your Macan is a GTS, it was not built that way by Porsche.
Old 06-03-2019, 01:19 PM
  #54
CarGuyNVA
CarGuyNVA's Avatar
In the black satin finish they are GTS-exclusive on that model. In other finishes the 20" Spyders are available on any Macan model.
Old 06-03-2019, 03:58 PM
  #55
jhbrennan
jhbrennan's Avatar
Follow these instructions. Next time test the light before you snap it back in (see step 6). LED's are polarity sensitive so you may just have to turn the blade connecter 180 and try again.
https://cdn.shopify.com/s/files/1/14..._Guide.pdf?880
Old 06-03-2019, 07:59 PM
  #56
///Bruce
///Bruce's Avatar
Got it!
Old 06-03-2019, 08:27 PM
  #57
jhbrennan
jhbrennan's Avatar
Got it!
Looking good...very nice. Great contrast with the red.
Old 06-03-2019, 10:24 PM
  #58
JWH7
JWH7's Avatar
Mine worked before I snapped it back in place and then stopped working. The LED connector is not very high quality and moves around a little in the bulb socket. I had to adjust the little wires on the LED connector to get it to work. They look great installed, but a somewhat finicky installation.
Old 06-04-2019, 10:25 AM
  #59
GoBlue!
GoBlue!'s Avatar
Looks great ///Bruce
Old 06-04-2019, 12:57 PM
  #60
///Bruce
///Bruce's Avatar
Thank you.
Quick Reply: Clear front side markers
