Cautionary Tale of Oil Leak (timing cover)
#31
Among the 85 results of a Google search for Porsche Macan oil leak is the following. A search for Audi oil leak produces more than 12 million results.
https://midwestperformancecars.com/p...dden-oil-leak/
https://youtu.be/9zZrDqD42IE
Porsche Macan Hidden Oil Leak
The Porsche Macan is a great vehicle, BUT, it is still a car, and it comes with its particular issues. Here is a video detailing a “hidden oil leak” that we have seen repeatedly on Porsche Macan models, regardless of age or mileage. Watch the video and learn why you should choose an expert independent shop for your fluids, filters, and other maintenance, even when you are still under factory warranty! A quality independent shop can save you a lot of money in out-of-pocket repairs.https://youtu.be/9zZrDqD42IE
Just coincidence, co-worker got the word this morning his 2014 Audi has a leak. Less than 60k miles and out of warranty. 1,900 to fix at the dealer ........... 1,100 at the indy.
#33
New to Rennlist, but found this thread googling the issue. I own a ‘16 Macan S purchased CPO at 23k miles. It now has 40k miles and has the oil leak issue at the timing cover. I first noticed an oil stain on the lower engine cover passenger side near the vents at 30k miles when I was changing the oil, but did not see a source or signs of a significant leak. Moving forward to 40k miles with another oil change - this time the alternator and all surrounding parts above were covered in oil. It was time for the PDK service and brought the car to our local dealer (Suncoast Porsche).
I notified the service advisor of the leak, the car was supposed to be serviced same or next day. A few days go by and I call for an update - the head tech was notified of leak and they weren't going to look at it until the lift bay for engine removal was free. Yikes - sounded like they were expecting the worst before looking at it. I asked if they had seen this before, but did not get a straight answer. Six days after dropping it off, they said they found a bolt was loose at the timing cover. They cleaned everything tightened the bolt, performed the pdk flush, and drove it 20 miles. No signs of leakage. So we'll wait and see now - will be pulling the lower engine cover every 500 miles now for inspection. Needless to say this is very concerning as I approach 50k miles and get out of warranty.
Posts on macanforums say bolts were sheered at the timing cover and the engine needed to be pulled to replace. $7-8000 job https://www.macanforum.com/forum/com...ak-anyone.html
#36
^ sounds like what others are seeing. timing cover leak, bad bolts, and $$$ to fix.
#37
Also, who knows if it will leak again if Porsche fixes it. Remember seeing another thread asking about looking at a used Macan with bolts replaced and asking if it will leak again, but no one replied. Guess it's too technical and not much time and experience on it happening or not happening again.
Edit: some replies are there now.
#38
Bingo. It's funny to me when people think that this is something their dealer would automatically tell them about when they get an oil change. Odds are they won't because oil changes usually aren't performed by the techs but by the junior guys who are told to crank through the routine services as quickly as possible. Sure, this would usually be covered by warranty that the dealer gets reimbursed for, but like you said, this engine out repair will tie up a lift for days and ties up a tech's time from generating revenue on other tasks.
Moral of the story is to have an independent mechanic check it if you are unable do check it yourself. Or at the very least directly instruct your service adviser that this is something you want specifically inspected.
#39
#40
But in the end, there’s nothing like keeping tabs on your own vehicle closely if you have the ability to do so. Nobody’s gonna care about your vehicle quite the way you do!
#41
Well said.
#42
that would be the timing chain cover, would it not?
I believe of the ~85,000 Macans sold in the US since its introduction, a handful (getting all the press apparently)
have shown the timing chain cover leakage issue. I have heard that possibly the root cause is/was the over
tightening of some of the bolts that secure the cover to the engine, resulting in their fracturing and losing the
ability to seal the cover to its gasket and the engine.
If 850 vehicles were affected, this would represent ~1% of the US Macan population - through 2018. Fewer, <1%,
more, >1%.
It would be interesting just how many Macans have shown this issue. The same for transfer case replacement.
more, >1%.
My 2017 MacanGTS just came back from the dealer having spent time there for both the timing chain cover and the transfer case issue...
#43
Received 1,607 Likes
Our Macan is in for a combo timing chain cover and transfer case service.
Here's the source of the leak at the top left-side corner of the cover. Note the 'loose' bolt...
except, it's not a loose bolt.
russw (08-09-2020)
#44
The timing chain cover uses dozens of these Torx socket head bolts. They are made of aluminum. The bolt above snapped in half right at the gasket. It was the bolt snapping that caused the leak.
Apparently these M6 bolts are a torque-to-a-low-spec (8 n-m) plus 90-degrees. The standard torque for a steel grade 8 M6 is 10 n-m. That 90 degrees probably puts it at 15+ n-m which is breaking territory for a steel bolt.
Aluminum bolts. Stupid. Stupid. Stupid.
When this job is done out-of-warranty by an Indy, I'm gonna bet good-ole-fashioned steel bolts go in.
#45
I'm no lawyer.
But, You sign to perform the work. Allowing them to do the job.
Then you sign to pick up the car for work performed.
If your car is close to end of warranty and you are questioning the repair was done correctly?
Should you be signing off on the papers, that the repair is good?
Could you leave the file open until there is proof of the repair? So don't sign and close the repair order.
My friend left his Audi repair order on an A6 for over a year while they chased an electrical issue.
It took them that long to find it.
If you are at the end of your warranty, would you not look for extra assurance?
