Adding Thule rack and "tow package"
Hi, all,
Considering a 2015 Macan turbo and need to add a rack to carry the mountain bikes. I know that 958 Cayennes with the pano roof simply cannot have a roof rack added if the factory rails are not [corrected and edited] place, but I was wondering if the Macan with pano roof has the same limitations. Thule is closed for the weekend, so no help there.
Also, I need to occasionally tow my 3000 lb 993 with my 900 lb Trailex to the shop about five miles each way. I know there are limitations with the PDK. How hard or easy is it to add a tow hitch and wiring if none are present?
Checked archives and results were thin if nonexistent.
Thanks for any help!
Etrailer.com does carry hitches that work with the Macan. Essentially similar to the Audi Q5 hitch. The wire harness was always the problem (splicing into it). They do carry a wire harness kit that does not require splicing. There are "pickups" that sense current going through a wire, so they clamp around a brake or tail light wire, and do not interfere with the electric load of the factory wiring. Use the trailer hitch to mount a bike rack. I have a Saris Freedom 2 bike rack that clears everything just fine in the 2" receiver.
https://www.etrailer.com/Custom-Fit-...leid=201744372
Thule has feet and fit kit for the Macan. I use a thule rack on my 15 turbo and it works well for light loads.
Not sure about the hitch, as mine came with one. I think there is a factory kit to add a hitch. You might want to check sites such as sunset Porsche.
If you're going to add a hitch and only tow occasionally, double up the hitch duty and get a hitch rack. You can get several versions, but I like the tray systems best. Next choice would be the uprights that "hang" the bike by the front wheel in a vertical rack type arrangement.
Still, I've been a big fan of fork mounts for quite a while and have a carbon fiber mountain bike that can't get clamped anywhere. The fork mounts are quite secure, too. Not sure how secure the trays are for theft, but my GF's Yakima trunk rack uses some cheesy cables that could be snipped with a pair of dykes in one second.
Thanks for the suggestion!
The Saris Freedom 2 rack straps in the front and rear wheel, and also straps around a "down tube" or horizontal bar on the bike. The bike is secure without the worry of clamping around the carbon fiber frame. It is very well cushioned.
https://www.saris.com/product/freedom-2
Get a heavy vinyl covered cable lock from Home Depot to lock up the bike to the bike rack. In the end, if the thief wants to steal the bike, they will get it. I also bought the locking hitch bolt from Saris.
Hmmm, I may have to re-think my bike carrying needs. When I sell my Sequoia, I'm going to get rid of my now-twenty year old Yakima system, so it's an opportunity to re-think the system.
As for fork mounts, with new standards and through axles, fork mounts are becoming more rare, not to mention a real hassle. The tray racks or hanging racks require no disassembly of your bike.
Take a look at the 1upUSA (www.1upusa.com), the new Yakima Dr. Tray and the Thule T2 Pro XT. I'm leaning towards the 1upUSA for my next rack, but now that Yakima and Thule have make their racks fit fat bikes, I'll consider staying with Yakima. Their warranty is first rate.
Than there's the hanging racks Northshore and Recon: http://www.northshoreracks.com/NSR%206-bike.htm and http://recon-racks.com/
My current set up:
And I can load and unload one handed, even, so if I've got a camelbak or helmet in one hand, I can still get the bike off and be ready to go.
