New RB CCB kit
Old Jul 17, 2017 | 09:04 PM
ShakeNBake's Avatar
ShakeNBake
I don't have the information you are looking for. I was the instructor in the car. I am reporting what I saw with my eyes and what I was told by the student. I have modified my account with "alleged" references.
Old Jul 17, 2017 | 10:24 PM
RacingBrake's Avatar
RacingBrake
Former Vendor
David Donohue's 991 Turbo S equipped with complete RB CCM brake kit competing in Pikes Peak race to the cloud this June.
https://rennlist.com/forums/991-turb...ikes-peak.html
https://rennlist.com/forums/991-turb...ak-record.html
Old Jul 17, 2017 | 10:59 PM
kfmcmahon's Avatar
kfmcmahon
Is nasal cannula oxygen routine on the PP hill climb?
If so...That's intense!
Old Jul 18, 2017 | 12:57 AM
RacingBrake
Former Vendor
Course Statistics
Length – 12.42 Miles
Surface – Pavement
Turns – 156
Elevation at Start – 9,390 ft.
Elevation at Finish – 14,115 ft.
Length of Plus Grade – 61,626 ft.
Maximum Plus Grade – 10.5%
Length of Negative Grade – 3,934 ft.
Maximum Negative
Grade – 10.0%
Average Grade – 7%
http://www.ppihc.com/wp-content/uploads/PPIHC2017-1.pdf
RacingBrake is proud to be designated by David Donohue to build a CCM brake system for his 991 Turbo S (in less than 3 weeks). And it's our honor to be part of this event.
Old Jul 18, 2017 | 01:28 AM
texasviany's Avatar
texasviany
I raced a car, and then a few years later, a bicycle up Pike Peak I really needed the oxygen for the bike race!!
Old Jul 18, 2017 | 01:49 AM
BryanCO's Avatar
BryanCO
Just need to run it...
http://www.pikespeakmarathon.org/
Old Jul 18, 2017 | 09:33 AM
d00d's Avatar
d00d
I like this 380/380 option better, and it should be under $9K;
https://rennlist.com/forums/porsche-...l#post14323612
Less weight than the 394/390 rotors, and caliper spacers aren’t needed.
It involves having to file down the bolt ends that support the pad (different from retaining plates on Cup caliper) about 1.5mm, to allow the 34mm wide CCB rotor to fit, OEM is 30mm.
Old Jul 18, 2017 | 07:52 PM
RacingBrake
Former Vendor
991 Rear Caliper (OE is for 380x30mm iron rotor)
This is where needs to be widened (from 34 to 37mm; 1.5mm per side) for a thicker CCM rotor (34mm) with proper clearance.
Another distinct advantage, other than low initial buying and replacement cost than pccb option, is this RB-CCM rotor kit is built with same CCM disc for all four corners, so they are totally interchangeable just like tires. For example if your front discs are more consumed (which is usually the case for tracking), you can swap the front pair to the back, or one side (driver/passenger) to the other (CCM discs are not directional)
Very flexible and economical; you only need one spare disc to cover all four.
Old Jul 19, 2017 | 12:02 AM
d00d's Avatar
d00d
Thanks, will you be adding a page to your site where this kit can be ordered?
Would be interested in sintered trackable street pads front and rear.
Looks like there isn't a lot of room to get a flat file in there.
Can those pad retaining bolts be unscrewed from the outside, and perhaps reassembled with a washer underneath it's head to get the additional clearance?
Old Jul 20, 2017 | 07:27 PM
RacingBrake
Former Vendor
Link to the item is up:
http://www.racingbrake.com/ProductDe...ode=POR-CRK-05
Old Jul 20, 2017 | 07:39 PM
RacingBrake
Former Vendor
Default Fitment note and pictures
Front set up 6 pot caliper w/380x34mm RB-CCB rotor:
Front OE pad clears hardware:
Top view:
This RB caliper spacer is used to show 997 (142mm upright) can upgrade to 991 GT3 6 pot calipers (225mm). For 991 upright this caliper would be a direct mount.
Rear set up 4 pot caliper w/380x34mm RB-CCB rotor:
Rear OE pad although marginal, but still can clear the hardware.
Rear set up top view:
Old Jul 25, 2017 | 01:46 PM
RacingBrake
Former Vendor
What kit you guys are more interested.
380/380mm kit (Under $9K) - This kit will simply replace OE's 380/380 iron rotors for an instant upgrade to CCM set up (Required to modify the rear caliper pad bolts).
http://www.racingbrake.com/RB-CCM-Up...por-crk-05.htm
394/390mm kit (Under $11K) - This kit has larger rotors (front and rear) and require caliper spacers (incl. in the kit) to install.
http://www.racingbrake.com/RB-CCB-Ro...por-crk-04.htm
We have more CCM upgrade options (including the complete system) for you to choose from, but the above would be the most popular ones to start with. Later on you can progressively upgrade to a complete RB CCB system with sintered pads (retain the same CCM rotors) for an ultimate brake set up that is good for all occasion (street/track/racing*), all the time (cold/hot environment).
Too expensive to upgrade to pccb ($25,000/system)?, afraid of high cost in rotor replacement ($6,500/rotor)? Can't decide whether to "pccb" or not to "pccb"?, we have the answer for you and RB CCB makes your decision easy and we want to prove to Porsche owners that this is a bullet proof braking set up you have been looking for, not only in performance (literally no dust on street and warp/crack free on tracks) but also affordable to own and worry free ow maintenance cost.
*With proper brake pad compound.
Old Jul 25, 2017 | 02:31 PM
d00d's Avatar
d00d
Thanks Warren.
I'm interested in the 380/380 kit because it's the closest to a direct swap.
I'll either file down the pad bolts myself, which can be done in or out of the caliper, or send them to you guys to do.
Here's the tool for removing the pad bolt;
http://kochtools.com/index.php?p=product&id=272
Old Jul 25, 2017 | 03:45 PM
notceo's Avatar
notceo
You should definitely NOT have problems stopping!
Old Jul 26, 2017 | 03:53 PM
stout's Avatar
stout
380/380 would be of more interest to me—keeps more stock gear in place, less likely to interfere with track wheel/tire packages, and the GT4 is already over-braked. This is a very cool product.
By Verdad Gallardo | 2026-04-28 19:00:17
