Rubbing issue with Spiegler brake lines
I was hearing an unidentified noise from the back of my car when the suspension compressed, so I took the car into a race shop that has worked on it before, in order for the shop to diagnose the issue. Turns out the Spiegler brake lines I had the shop install were rubbing on the inside of the rear wheels and tires when the suspension compressed. The coating on the brake lines was worn through. The shop has fabricated a bracket to keep the lines away from the wheels but they think the lines should ideally be a bit longer to keep them from being streched at full extention with the bracket installed. The Spiegler kit is the 6 line one that is designed to be used with caliper studs and I am running HRE wheels in OEM sizing and offset. I have not actually seen with my with my own eyes yet how the rubbing is occurring, as the shop is about an hour drive from me, and I am hoping to get it resolved before I go back there to pick up the car, but I thought I would ask if anyone else has had this happen to their car.
I had the exact same issue on my rear lines with OEM wheels/tires except lines were the RB set. In my case it was just a bit of wear on the plastic sheath over the stainless line and I agree that it was probably only during suspension compression. My shop bent the line bracket slightly and wrapped the lines with some cloth tape and there has been no wear since I went to 19" forgelines. When I run the OEM wheels again I'll check and see if it's still a problem
I had the exact same issue on my rear lines with OEM wheels/tires ..... My shop bent the line bracket slightly and wrapped the lines with some cloth tape and there has been no wear since I went to 19" forgelines. When I run the OEM wheels again I'll check and see if it's still a problem
I have these on my 981S. No issues with rubbing. In my case, I bypassed the bracket that the original two line version in the rear connected to. I did have to bend the bracket back a bit so it would not interfere with the lines. Its very important when installing these lines that they are rotated properly before tightening. Otherwise they may very well rub against something. That is especially important in the front where there is more stuff to clear. FWIW, and I told Essex this, IMO, the first section of the front lines that come from the fender to the bracket aren't necessary. I didn't notice any difference in the feel of the brakes after installing this kit. The only reason I put them on is because I use caliper studs and like the added safety of having a flexible line.
The shop that installed the lines said that they did rotate the fittings several times to see if the lines would behave as desired but to no avail. The shop is very experienced and has an excellent reputation in the racing community, so I do not think this is an installation issue. Installing brake lines can only be done so many ways for any given set of lines and it is not complicated. I am still gathering facts from Essex and the race shop to try to find out why this set of lines is rubbing and will report back after I have more info.
If you do not need to install the lines before VIR then I would just wait until after the event. I think more answers will be forthcoming. Like others here, I only installed my lines to allow the calipers to be removed with the caliper studs in place. If you do not have caliper studs yet, and you don't plan to install studs on Friday with the brake lines, I don't see any reason why you would want the lines to be installed now.
The rear lines appear to be fairly taut with the wheel at full downward travel. The key is to get them to bow in a different direction during compression rather then right at the wheel/tire. I think a shorter line would have other issues though given the above. I was ready to switch to the spiegler lines if this had remained an issue on my car. (Assuming they would be designed differently) Sounds like they have the same problem.
When I had the Tarett springs installed and the dampeners were off we moved the rear wheels full travel and messed with the bracket until the lines bent in a direction parallel to the wheel. That and running 10.5" rear forgelines gave plenty of clearance.
