Photo of GT4 Emissions Sticker?
Anyone have a clear photo of their GT4 Emissions Sticker (located under engine cover)?
If so would you mind sharing it, either here, or via email?
I understand all stickers are identical and specific to the model (no VIN info on sticker).
Thanks in advance!
Thanks in advance!
Here is the sticker, and location.
Note that once you lift the carpet (assuming all GT4's are the same) - the sticker is at the front-most edge of the engine hatch just behind the seats. The sticker faces the seats - so if you take a photo from the rear, it'll be upside down. It's placed as though they expect you to see it from the cabin. Kinda crazy - but here it is. My buyer (of the yellow GT4) is from CA and they are quite strict about emissions and I completely understand his interest in verifying the car had the proper credentials.
The sticker has it's own part number. In the event it is missing or damaged it can be reordered.
GT3 player par excellence
lol
i was just going to ask
if ur buyer is californian
i had to do the same
integra891 (01-01-2021)
Just bought a 981 GT4 from OR and drove to CA. This is great information. I went to a local smog check place and the owner requested to get some info from the vehicle emission control information sticker. I would appreciate if someone can confirm that all GT4s have the same sticker as the picture above. Thanks.
I just had to do this in CA as well for an out of state vehicle. It is in the same spot as above. I used youtube videos to figure out how to access it, remove a few trim pieces and the carpet just lifts off.
I'd rather not have to go through all the steps in the video to remove trim pieces to gain access to the emission sticker. Also, I didn't want to inadvertently break plastic tabs on these trim pieces. Does your sticker have identical info as the one in the picture above? Thanks
A lot manufacturers only send "50 state" legal cars at this point, it just makes more sense for them. It's likely all US bound GT4's were Carb legal. For instance NY requires new cars be CARB compliant, we don't have the same strict inspections but they want the lower emmisions threshold. There's several other states who have piggybacked on California as well (for base standards).
I ended up ordering the sticker from Pelican Parts ($15) using the part number in the picture of the sticker in the post above and stuck under the trunk lid.
