Sponsored by: APR
GT4 common problems and solutions?
Old 01-21-2018 | 06:52 AM
  #46
Asif's Avatar
Asif
3rd Gear
Default GT4 making ticking noise
Originally Posted by 4carl
Thought it would be useful to put together a list of common problems that are popping up and the solution.
Ill start the list from what im aware of from posts.
-Parking brake fault -- Solution ?
-squeaking clutch pedal -- Solution?
-clunk in rear suspension -- Solution?
-leaking rear shocks -- Solution?
i know im missing some please add...
I Had a first oil change done recently and since then I have noticed a quiet but irritating ticking sound from engine mostly on overrun as the rpm drop below 2500. It occurs when the engine has warmed up and I don't hear it on start-up or while engine is warming up. I took the car to my local OPC and their senior tech agreed that there was an unusual noise from engine but wasn't sure if this is a characteristic of engine on GT4. They have opened a case with Porsche GB and I am waiting for an update. The car drives well and I have no warning lights. I am just wondering if any Gt4 owners have noticed anything similar with there cars.
Old 01-29-2018 | 11:56 AM
  #47
exacc's Avatar
exacc
Yes, this same exact issue happened to me also. Had a simple oil change and air filter change last Dec, and as soon as the car came out, I immediately noticed it. It wasn't there at first but as soon as the engine warmed up it was there. Only on overrun and only between 2500 to 1000 rpm. As soon as it is idle, it is completely gone. Weird that it happened exactly after the oil change as well. Please let me know if any updates were given to you or if you have resolved this issue.
Old 01-29-2018 | 12:09 PM
  #48
ShakeNBake's Avatar
ShakeNBake
Originally Posted by mooty
no problem that's not self inflicted.
Ain't that the truth brutha.
Old 12-30-2019 | 04:22 AM
  #49
HenryPcar's Avatar
HenryPcar
Old 10-03-2020 | 03:04 PM
  #50
HenryPcar's Avatar
HenryPcar
subscribed
Old 10-18-2020 | 06:55 PM
  #51
DR.S's Avatar
DR.S
Regarding the ticking noise in overrun / deceleration conditions:
I guess the ticking is absent if oil pressure is at least 2.0bar (29psi) and just audible if it falls below.
Maybe others can confirm / observe.
Old 10-21-2020 | 04:30 PM
  #52
RobC4sX51's Avatar
RobC4sX51
Ditto
Originally Posted by orthojoe
Yes. For me, it's coming from the brake ducts hitting the wheel weights on my 19" wheels
