GT4 Power Package Options
#31
for people that track the car with aftermarket cats I would definitely reccomend you check your headers before every track event which will get old quick! You need to do this so you don't have all that debris suck back in the engine and could cause you to replace the entire engine which is not covered by warranty!
Point is if you track no point in getting cats bc it won't last and could ruin engine. Wish someone would have told me this before.
#32
Basic Sponsor
For you guys deciding between race or sport headers.....
If you are going to track it, get the race headers. I found out, much to my chagrin, that the HJS cats are not for track use and will start coming apart after 6-8 very hard track days. Ask me how I know.....actually don't, I'm a bit bummed with my CG sport headers at this point.
I hope you're recovering well and on the mend Jacy.
@JSLee - did we sell you manifolds as well?
#33
For what it's worth, we had a failure on the factory ClubSport manifold too because cats really can't handle the long straights at WOT. While Cargraphic has offered to suggest a more Motorsport oriented cat, if you're using the car on a race track and off-road, following this information we are suggesting catless headers for off-road use only. The owner of the company just pinged me after reading the comments so please let me know what we can do to resolve the issue and again, if you've already had your shop determine they're failing, I'm not aware so I apologize if that's the case and I'm not up to speed. Sometimes on the 987.2s the cats would free up and cause a CEL on when running a stock file but if you've looked in there and have seen them breaking down, this is the first I'm hearing about it. I can get with Cargraphic on Monday and see what they want to do but I know their stance and everyone's on tracking. Those that don't go on track, this is not a concern.
Thanks for addressing! May need to switch to cg just for customer support.
#34
Basic Sponsor
I'm just trying to do damage control and it's clear to me that going forward, even tho a lot of folks want headers with cats to avoid a need for a tune and pass emissions, if you go on track, longevity will be compromised. I am subscribed to the thread...anyone else who wants to weigh in, please do. Remember though, even the factory header on the race car with the cat has the same issue.
#35
Not really seen this breaking apart on the factory Porsche gt3 parts. Many many track days on cup headers which are 100 cell cats.
Anyway if your cats are falling apart just finish the job and bust out all the material. Headers. Old Skool jdm style lol
#36
#37
This is interesting and more information is warranted - can those who had the cats fail on the CG sport headers or other brand let us know what other modifications you had made to your car (TB, Tune, Plenum etc.) and who the mfg. of each of those parts might have been to see if there any common parts involved?
Any idea on what has been the cause - excess heat or poor mfg. quality of cats? Could it be the result of the tune, the conditions at the track (hot humid day) or ?
Are all MFG.s using same cats? Fabspeed, Cargraphic, Dundon, GMG etc.
Seems like once again there is a track solution and a street solution - but stock may be the all around solution!
#38
#39
Issues that people might be having with aftermarket equipment aside, the level of service that BGB provides is pretty damn incredible. I've been on car forums for a long time, and I've never seen that kind of attentiveness that BGB pays to their customers that they do on RL.
And in the case of CG, BGB is just the middleman! Very nicely done.
#40
Most of the aftermarket cats I have seen lately are metal foil in construction. I believe the factory cat is a ceramic monolith. When the ceramics start to fail they will frequently begin to melt and block off part of the flow. The metal foil will fracture and result in metal shards going downstream of the cat.
If the cat is ceramic you can use a 3/8" drive to break up the ceramic and shake it out of the shell. If it's metal you may be in for a lot more work.
#41
Installed IPD plenum and 82mm TB, CEL went away after a few starts.
Dundon headers are being built.
I didn't install an aftermarket filter because the increased engine wear isn't worth the few horse powers.
2016 white/black GT4;
https://rennlist.com/forums/gt4/9321...e-journal.html
2008 white/amaretto S8
#42
Be careful to not breathe the precious metals dust when gutting a catalyst.
Yes, no tune or other performance modifications other than 82mm TB and plenum, and no CEL after a few starts.
I didn't dyno, and Dundon reports no improvements with these components so far, but I've noted more intake noise and maybe some increased HP.
Removed the rear of engine carpet pad and there was way too much at that point, so reversed that.
#44
The best part of catalytic converters failing is when the junk cat material happens to destroy the front O2 sensor, then bye bye motor?
http://www.planet-9.com/987-cayman-a...d-headers.html
"Race headers for racecar" Always
#45
Looks like FS had used an unnamed brand 100 CPSI metallic catalyst that require strengthening rods, then switched to the quality HJS 200 CPSI metallic catalysts that don't;
http://www.6speedonline.com/forums/9...00-cell-2.html
The metallic matrix catalysts also use ceramic as a coating, but are more resistant to race condition impacts than a ceramic matrix, from http://www.hjs-motorsport.de/downloads-en.html;
