GT4 Suspension Squeak
Old Aug 14, 2016 | 07:42 PM
Wells's Avatar
Wells
Default GT4 Suspension Squeak
Hi Folk this is my first post and I have a slight problem. I picked up my new GT4 on Thursday, and I have covered 900 miles this weekend! I wondered if anyone has come across a kind of squeaking noise from there rear suspension? It seems to be coming from the drivers side rear (RHD) on fairly smooth motorway. It almost sounds like air in the shock absorber. Have any of you guys experienced the same? Thanks in advance.
Old Aug 14, 2016 | 10:29 PM
orthojoe's Avatar
orthojoe
Check underneath your struts and look for a leak. Mine is doing the same.
Old Aug 15, 2016 | 03:52 AM
cox1974's Avatar
cox1974
Mine too...
Old Aug 15, 2016 | 03:53 AM
cox1974's Avatar
cox1974
https://rennlist.com/forums/gt4/9442...miles-gt4.html
Old Aug 15, 2016 | 11:01 AM
Rac10000's Avatar
Rac10000
Mine as well ... haven't dealt with it yet but it's more of a high-pitched squeak (not a clunk).
Old Aug 15, 2016 | 01:13 PM
zmon's Avatar
zmon
i hear a squeak back there (drivers side) also. have not done anything about it yet and have not seen if my shock is leaking.
Old Aug 15, 2016 | 09:06 PM
Wells's Avatar
Wells
Hi Guys, Thank you all very much for your replies. I have pulled the wheel off and the shocks are as dry as a bone, and everything is nice and tight. Looks like a trip to the dealership for me.
Old Aug 15, 2016 | 09:21 PM
Leuz's Avatar
Leuz
Is the squeak loud? Can you hear it when driving on bumpy roads? I'm trying to identify if I've got the same problem as I do hear something but thought it was coming from inside the cabin, instead this post made me wonder whether I've got the same problem or not...
Old Aug 15, 2016 | 09:30 PM
Wells's Avatar
Wells
Its loud enough to be very annoying and as its quite high pitched, turning the radio up doesn't work. You can hear it on bumpy roads and also smooth. The slightest movement of the suspension seems to cause the squeak.
Old Aug 16, 2016 | 03:53 AM
cox1974's Avatar
cox1974
It's suspension related... I have it since the first time i drove the car...after 10000km i found that the rear shock was barely leaking...
Old Nov 11, 2017 | 08:06 AM
Betternotbigger's Avatar
Betternotbigger
Just acquired a "new" GT4 with only 350 miles on the clock. Car is epic but mine seems to have the squeak AND the clunk. To be honest the clunk is not particularly prevalent, the squeak however is constant.
Am I right in surmising from this thread that replacement struts under warranty are in order, or is there a known tech fix at the local Porsche centre?
Old Nov 11, 2017 | 09:08 AM
cox1974's Avatar
cox1974
new shocks under warranty ;-)
Old Nov 11, 2017 | 10:06 AM
Betternotbigger
Thanks for the quick reply. Did a swap fix your squeak?
Old Nov 11, 2017 | 02:23 PM
cox1974's Avatar
cox1974
yes all perfect with new parts....;-)
Old Nov 11, 2017 | 02:26 PM
Betternotbigger
Great to hear. Hope you're still enjoying the car.
