DSC box
Old Aug 1, 2016 | 02:47 PM
Beantown Kman's Avatar
Beantown Kman
^^^ I stand corrected. It sounds like the DSC is designed to work over quite a wide range of spring rates. Othojoe will have nothing to worry about. Hard to imagine many people would consider using higher rates than 700/800 on this car and still plan to drive the car on the street.
Old Aug 1, 2016 | 02:58 PM
orthojoe's Avatar
orthojoe
Sweet!
Old Aug 1, 2016 | 09:08 PM
usctrojanGT3's Avatar
usctrojanGT3
Can we get a group buy going then?
Old Aug 1, 2016 | 10:18 PM
Terry L's Avatar
Terry L
Originally Posted by mrd_spy
that is some high PSI in those tyres 36/38 !
Well, that is where the car felt best to me. YMMV. However, if you look at Hoosier's suggested tire pressures for DOT radials, 36-40 is the recommended hot range for cars weighing 2800-3000 lbs. I have Pirelli slicks on my faux Cup car and they shouldn't go above 29 or so.
Old Aug 1, 2016 | 11:26 PM
Beantown Kman
Hoosier's recommendations are BS. They say this because the tires will be safer and more reliable at these higher pressures, especially when they are cold. But, safety and reliability aside, these tires will perform MUCH better at lower pressures.
Old Aug 1, 2016 | 11:32 PM
supercup's Avatar
supercup
To included DSC and Swift springs - 448/560 (one's Tarett is selling as GT4 upgrade kit) with DSC mapped for that! Would be a nice package for GT4!
I was looking at adding exactly these two items!
Group buy and I am in
Old Aug 1, 2016 | 11:43 PM
Gilou Panizzi's Avatar
Gilou Panizzi
For someone far from all those technical specifications, what would be the purpose of this dsc on an exclusive street use ?
Old Aug 2, 2016 | 12:07 AM
KingSize.Hamster's Avatar
KingSize.Hamster
The car is more comfortable, and the handling is sharpened up
Old Aug 2, 2016 | 12:08 PM
Gilou Panizzi
Thank you. I don't particularly find mine uncomfortable, although roads are not perfectly flat in some sections . However, I experience some weard ABS reactions, or intrusions if I may, on hard breakings as soon as the ground surface becomes irregular.
I read in another thread that those reactions could appear because of irregular surfaces. I also wonder if it's a suspension problem, or maybe because my brakes are note fully broken in. And if it's a suspension problem because of bumpy roads, maybe that DSC could help?
Old Aug 6, 2016 | 12:37 AM
Terry L's Avatar
Terry L
I'd love to see some data on this.
Old Aug 6, 2016 | 04:26 AM
cox1974's Avatar
cox1974
Installed my dsc yesterday.... On our very very bad road... The car seems more comfortable and "light" on the road roughness....not tried yet in stiff mode on some good roads....
