Replacing Lip
Old Jul 31, 2016 | 03:25 PM
ChrisF's Avatar
ChrisF
Default Replacing Lip
Ok, did this a bunch of times on my 997 GT3. Two screws, pull down; push new one in, screw back in; done!
Pulled the two end screws, pulled and nada. What am I missing? Explain to the moron how it's done
Old Jul 31, 2016 | 04:00 PM
Mech33's Avatar
Mech33
If it's anything like the 991 GT3, you pull hard until it feels like it's going to break, and then you pull harder.
Old Jul 31, 2016 | 04:18 PM
24Chromium's Avatar
24Chromium
It always helps to look carefully at the new part to see the exact attachment features. That usually is enough to figure out how to remove the old part.
Old Jul 31, 2016 | 04:52 PM
DrPhil Gandini's Avatar
DrPhil Gandini
When I did this I had to pull harder than I expected. The shark tooth part is on the top, so pulling up will jam the tooth, pulling down might work better. It's easier once you get around the corner toward the front of the car. Good luck.
Old Jul 31, 2016 | 04:57 PM
ChrisF's Avatar
ChrisF
Thanks. Will take a look.
Old Jul 31, 2016 | 10:51 PM
mooty's Avatar
mooty
GT3 player par excellence
i just did that yesterday
pull HARD like you are trying to pull the whole car into the trailer, firmly, slightly downward
only two screws at each end.
Old Aug 1, 2016 | 02:18 PM
Perimeter's Avatar
Perimeter
One of the benefits of the tapered "shark tooth" profile is you can get a tool in behind it and release each tab clip
