OEM 20" GT4 Bridgestone RE-71R status
#76
Hello everyone. I've been watching with much interest in anticipation of when I'll be needing a new set of tires. I see that most of you are anticipating the Bridgestone RE-71Rs for track use in lieu of Michelin Cup 2s because they cost less and have similar wear and performance. I regretfully will not have access to a track in the near future (1-2 years). What are your thoughts about replacement for spirited street use? My GT4 came with Dunlops instead of Cup 2s. Would you go with the Bridgestones over Michelin PSS in my circumstance?
#77
#79
Good advice mostly. One thing I would be aware of is tread noise. Last time I had kumhos 7 years ago on my old mini they had tread noise like a monster truck. Since the Gt4 let's a lot of noise in as it is, tread noise can get grating on longer drives.
#80
For spirited street use, the Cup2 and Sport Maxx are good choices... plenty grippy enough, and can get buy in the rain better than the RE71R.
Also, Conti has a similar use tire as the OEM... the Contiforce Contact. I am mounting a set today, and going to the track all weekend... so will post up my review afterward.
Basically, similar performance to the OEM options... but a little lower price and better wet performance if you ever hit the wet. Seems like a great option for a street tires, and/or also a backup set for rain use if you have a separate set of wheels for dedicated dry track tires, such as the RE71R.
#82
Hi Damon, what's the estimated date that these tires would be shipped to customers? My cup2 are completely worn. I'm desperately in need of new tires.
#83
Former Vendor
At this time we are estimating between 10/5 and 10/14 to get them into stock here. Delivery to customers is usually 1-2 days once we get them into stock.
#84
the two factors that affect wet performance is the rubber compound and the
amount of siping in the treadface to channel away water. Comparing the Cup2
and RE-71 tread, they are close, but I'd give a slight nod to the Cup2 tread
being possibly more water-capable. On the other hand, from what I've heard,
the RE-71R compound is softer and works better at lower temperatures than
the Cup2 so that would give a slight nod toward the RE-71R. Neither is a cold-
weather compound though.
So I don't think water concern is going to distinguish one from the other.
#87
And if you want the best of both worlds... I've been trying a set of Continental ContiForce Contact and their wet performance is supreme to any other streetable track tire I've used, and the dry ain't too shabby. I'm running 20" oem sizes, and they seem to be holding up well to track life, but a bit more sensitive to pressures and heat... they have a narrower performance envelope than the SC2 and Sport Maxx.
#88
To clarify, for warm misty conditions... the softer RE71 is probably better... but when standing water and water evacuation comes in to play, the Sport Cup2 and Sport Maxx have better warter evacuation.
Curious minds want to know.
#89
On what do you base your rain traction/evacuation comments? The RE71Rs are not yet available in OEM 20" sizing. And what about the comparison of MPSC2s, Sport Maxxs and ContiForces. Is there a test that shows all three together? Have you driven all back to back to back?
And I need them... my OEM front Dunlops only lasted 3 days. :\
#90
My RE71Rs in OEM sizes were also shipped last week. I've run them in 19" size and they are much better than the stock Dunlops at cooler temperatures. The Dunlops need to be hot to grip, but the RE71Rs grip at all temperatures.
