Removing screens from instrument panel display
Old Jun 27, 2016 | 03:41 PM
DrPhil Gandini's Avatar
DrPhil Gandini
Default Removing screens from instrument panel display
I searched but nothing came up. There's a panel on the multi-function display that shows a performance graph (looks like a sort of torque or HP curve) with a dot to indicate where you currently are on the performance curve. I personally find it annoying.
But to my question. Has anyone found a way to remove this screen from the display, so that if I am in the base display (temperatures, etc.) and then push the selector lever up once, I get the tire pressure display, rather than the performance curve? I realize I can scroll through the displays, so a secondary question might be has anyone figured out how to rearrange the order of the displays as you scroll?
thanks.
Old Jun 27, 2016 | 03:57 PM
ExMB's Avatar
ExMB
Should be covered in the owners manual (good to know app) under display settings
Old Jun 27, 2016 | 03:58 PM
jphughan's Avatar
jphughan
Yep. While under Vehicle, go to Settings > Display and you can uncheck any of them. I have mine set up only to show Vehicle, TPMS, and Map because those are the only 3 I ever really look at, and it gives me one-step toggle between the vehicle temperature and TPMS displays on track.
Old Jun 27, 2016 | 10:35 PM
DrPhil Gandini
Perfect! thanks jphughan +1
Old Jun 28, 2016 | 01:17 AM
Alan C.'s Avatar
Alan C.
25 Year Member
Thanks for the tip.
