Gear shift assist and g-meter without SC (USA)
#62
Gear shift assist and g-meter function are not included if you don't have SC. There are folks who got those enabled at dealer after delivery. But I'm always under the impression that is for ROW and in the USA these can't be enabled.
Appearantly I was wrong. I took my car to the dealer recently to reset a service reminder. They couldn't reset the reminder through the regular reset method so they went the far route to reset the entire system. I suppose that might have been an ECU reflash. When I got my car back, I noticed both options are now enabled.
#66
I just had mine done yesterday. Have the tech code the car for sport Chrono. It will generate some errors. Then clear errors using PIWIS. Then everything should be fine.
#67
How many of you guys actually find this useful? I don't feel comfortable looking down at it first of all and to me it's no better then watching the tach. I've gotten to the point where I'm shifting more by feel between the sound of the motor and the rate of acceleration. When I look at my track videos it appears I'm reasonably consistent without it.
#68
#69
#70
There's a gear display in the tach for that purpose, but how does knowing what gear you're in help avoid a money shift? If you want to upshift, you need to either pull straight down or push upwards and to the right. If you're not sure you CAN safely downshift at your current speed, then you need to know your revs (or your speed if you know your gearing), not your current gear. But honestly I've never found myself unsure of what gear I'm in under potential money shift conditions. To be at risk of a money shift while currently being in 2nd-4th, the gearing requires me to be in the 4500-6000 RPM range, depending on gear -- let's say 5500 RPM for the sake of discussion. Right off the bat, differentiating 1/3/5 from 2/4/6 is trivial because the lever is either up or down. You can't money shift upwards from 3rd or downwards from 2nd, for example. And once you've narrowed it down to the appropriate half of the possible gears, the speed difference between gears should be plenty. 5500 RPM in 1st is ~35 MPH and in 3rd is ~78 MPH -- those are easily differentiated. And 5500 RPM in 2nd is ~56 and in 4th is ~97. Again, easily differentiated. Those gaps get even wider higher in the rev range. So what's the problem?
#74
It's useless. However, those individuals on this forum who wanted to know how best to close the trunk to minimize fingerprints may find it useful. I'm not kidding...there is a thread on how to close the trunk.
#75
Originally Posted by seapar
I have found it a bit useful to remind myself what gear I am in before "not money shifting". The lights do not help. Shifting by sound is better.
