Has anyone who has either DIYed this or who has access to PET advise whether the GT4's gearbox drain and/or fill plugs have washers that should be replaced? The PDF says there may or may not be washers. If there are, do the gearbox plugs and washers happen to be identical to the plug and washer used for the engine oil drain? If so I'll just order a couple of those from Suncoast since they stock them.
The reference to the dipstick is for the 5 speed trans axle. Thankfully the 6 speed you need to have the oil coming out of the fill hole and you are good.
The gear oil from PET is Mobil 1 Mobilube PTX 75W90 liter bottle
P/N 00004320420L .
Sun Coast is the only source I've found for the liter bottles. You'll need approx 3.2 liters. PIWIS is not required.
Both applications use a crush washer. I'm going to install magnetic drain plugs.
Engine drain plugs
P/N 900 123 106 30 sealing ring 18 X 24
P/N 900 219 020 31 screw plug M 18 X 1,5
The Spyder PET is incorrect on the trans axle drain and fill plugs. They are not M18 and they are made of steel.
Reason: New findings, deleted trans sealing rings
Whats the reference to the homemade dipstick in that document? No further text on how to read it.
Typically it's just a paperclip bent into a J shape and you just dip the short end of the J into the fill hole with the horizontal part resting on the bottom of the fill hole. That will tell you how far below the fill hole the fluid level is.
P/N 00004320420L .
Also the drain plugs are common between the trans axle and the engine and are M18 X 1.5, different from the procedure. Both applications use a crush washer. I'm going to install magnetic drain plugs.
Engine and trans drain plugs
So the instructions in the PDF for the 6-speed about filling it to overflow, waiting 10 minutes for it to level out, and then filling to 2mm below the fill hole don't apply to the GT4's gearbox?
According to GTGears, the OEM gearbox drain plug is magnetic, but I'm not sure about the engine oil plug. I'd completely forgotten about that, although it looks like they share a common part number? If so, it sounds like we'd be good to go just ordering the drain plug that Suncoast lists. And out of curiosity, what is the 24 dimension on the sealing ring description?
I bought a spare Porsche trans axle drain plug to be sure of the thread size. It is steel. Of course the Spyder PET is wrong: the trans axle drain plugs are M22 X 1.5.
As for filling this is what AllDataDIY says:
Use manual metering pump WE 1372 to fill in transmission oil up to the lower edge of the filler opening.
Reason: Added actual trans axle drain plug thread size
Thanks! Ok, so just top it up and definitely replace the sealing rings. Perfectly clear and easy.
Although this indicates that the plugs are M22, not M18 like the part numbers mentioned above. Which are they? I know this PDF is for the regular 981, but I thought the transmission is essentially the same. Would Porsche really have just changed the plug size?
I'm not sure I would take a 17 yr old tech info with allowable replacements as valid just because 1 part number matches up. Changes have happened. When I checked with my dealer they haven't received an approved substitute similar to the listing they had for 987.2 mechanicals.
