Alignment Issues
Old Apr 19, 2016 | 11:13 AM
  #31
myBailey07's Avatar
myBailey07
Originally Posted by jphughan
Quick question I just had after looking under the rear of my car. I have the locking plate kit to remove the eccentric bolt on the toe links, but I just now realized that there's another eccentric bolt on what I think is the LCA. I assume this is used to make camber adjustments without messing with shims, but does this one tend to stay in place even at the track? If not, is there a separate locking plate kit for that one, or is that just not a feasible option because the shims don't allow sufficiently fine adjustments?
FWIW, I have never had issues with my camber slipping after track use; however, I have now had my car aligned 4 times (original, two times to figure out rubbing and once after off) and every single time my toe settings moved pretty substantially. I now have the locking kit on order - should have done it first time.
Old Apr 19, 2016 | 02:05 PM
  #32
Bill Lehman's Avatar
Bill Lehman
The rear camber eccentric can definitely move. Make sure it is torqued to the correct spec.
Old Apr 19, 2016 | 03:37 PM
  #33
jphughan's Avatar
jphughan
Do you have that spec handy by any chance? If not, I noticed that the shop I used for the alignment and corner balancing drew a line that runs from the bolt outward, so I'll have that visual indicator of something having changed.
