Shake, did you end up putting caster bushings in the rear as well? At -2.5 in the back I can see the wheel started to be pushed back in the well noticeably so. Just curious. I had to go back to -2 in any way in the rear as my 20's are rubbing at the top outside fender at -2.5 as the shims push out the wheel a few mm's too much.
I got to -3 front without issues using shims, front toe link and caster bushing. This is probably the max and going any higher camber plates are the way to go.
As to jp's comment, I have no idea at what point cup monoballs are needed. I did not need them at -3.
How much shim did you use to get to -3, and what was the position of the top mount? Orthojoe mentioned using the Cup monoballs because they incorporate a thick shim and include longer studs to allow more shim to be added without falling too low on LCA thread penetration. Porsche evidently recommends at least 1" of thread in the LCA.
Good question. Answer is I don't know on how much shims. I'll have to crawl under car to try and measure to see how much. Soulspeed just did it for me. The top mount is pulled all the way in at max. I do have the aftermarket front toe links as well, so toe isn't an issue. I do know from what what Colin at SS said and from discussions with others that for above -3 you probably need camber plates, but I can't knowledgeably speak about the monoballs as I just don't know. Anyway, at -3 I am as far as I'm gonna go, so unless someone has definitive reason for me to change anything I am done.
Yes, I had to add thrust bushings in the rear (which are already solid BTW) when I increased to -3, it was too close to the liner and rubbing on full compression.
In the front, we moved to a camber plate, which let us run fewer mm of shims, but easily get to -3.5. Trivial to get a 265 on the front now, plenty of space - could even go bigger, but I don't think it would help much.
I think that's right. I don't think you could do more than -3.2F without upping to a different end-link with longer bolts (unless you combined with camber plates too)
Just a note on this issue of threads on the LCAs. I added 8mm shims and removed one of the (two) spacers on the LCAs that are between the nuts and the LCAs. There is still one spacer, the nut and some threads protruding. I got -3.1 with the tops all the way in. Of course the toe was amazingly wrong, and I would have needed new tie rods, I expect. I went to -2.1 with zero toe and it all snugged up just fine, with lots of slot left at the top. Just another data point.
We are working on another GT4, and he is going with 6mm shims since his top slots were not as "bad" as mine. Seems like a bit of variation from the factory on these cars...
Thanks all. I have a pretty good understanding of what mods are needed to achieve most desirable settings after reading threads and posts from many of you.
My question was whether or not anyone has heard of a factory acknowledged issue with the rear subframe that is limiting suspension adjustments. Apologies if that was not clear.
I was planning on autocrossing in stock class which prohibits mods.
Who's using the Tarret front tie rods? I have had discussed with a few folks and many believe you need them for more than 2.5 of front negative camber.
Fyi, in addition to variances in the cars themselves (I only got -1.5 camber in the front bone stock whereas others got -2, for example), what's achievable before needing tie rods would depend on the toe you want along with your target camber. A track-optimized setup that has a bit of toe out in the front might not be achievable for a given amount of camber, whereas a street-optimized setup that had 0 toe or maybe a hair of toe-in might work with that same amount.
Wow!! What's your front toe and caster? I thought for sure you'd need thrust arm bushings, tie rod ends, and maybe even Cup monoball ends for -3 in the front with reasonable other numbers. And how much shim are you running in the front?
Neutral toe. Caster 10.5. Lots of shims, can't remember. Park Place Motorsports did my car. No lowering either.
Impressed that you hit -3 and 0 toe with only shims, but that amount of caster will probably cause you to rub under full lock and/or high-load cornering. I'd keep an eye on your tires, since others here have rubbed with a lot less caster than that. I'm also curious how much LCA thread engagement you've got left. You must be right up against the safety margin with the top mount already maxed out.
Not necessarily. A lot of it depends on the offset of your wheels as well as the size of your tires in addition to the track.
Quick question I just had after looking under the rear of my car. I have the locking plate kit to remove the eccentric bolt on the toe links, but I just now realized that there's another eccentric bolt on what I think is the LCA. I assume this is used to make camber adjustments without messing with shims, but does this one tend to stay in place even at the track? If not, is there a separate locking plate kit for that one, or is that just not a feasible option because the shims don't allow sufficiently fine adjustments?
