Graphics
#33
Master list:
**NOTE** Per Dan all of the vinyl has to be gloss
RDCR: 1 set black, 1 set Red, 1 set yellow
Mecho: 1 set in Red
Buteo: 1 set black
Scottykenneth: 1 set black
tasman: 1 black, 1 set Red
realdrray: 1 black, 1 set Red
mhoffman: 1 set black
etp:: 1 set black, 1 set orange
monochrom3: 1 set black
Jimmy-D: 2 sets black
needmoregarage: 1 set black
supercharged man: 1 set in satin black
RAC10000: 1 set Satin black
Steve D: 1 set black
GourmetMBA: 1 set black
Halfshaft: 2 sets in black
Joemat: 1 set black
jgarvish: 2 set red
Qship: 1 set black
Stingray 84 1 set: 2 black, 2 red
Gibbons: 1 set black
Guys: please don't PM me with your order post it here on the thread.
Keep in mind a "set" is 4 decals. You can get 2 different colors - 2 each color in one "set" if desired. They sound a little tricky to put on so it's not a bad idea to have 4 decals in a color in case you screw up.
I'll probably cut this off at 20 people because I don't have enough time to deal with much more then that!
Just in from Dan:
"In order to install the decals successfully in the indent they will need to have a gloss finish. The gloss allows the film to lose its memory when applying heat. Also, you will need to lick your finger which will conform the film to the concave. A gloss works better for this highly technical procedure"
Sounds like everyone should expect a gloss finish, especially in black. I'll go ahead and write down everyones black request and talk to Dan about what will work but it sounds like black may be limited to gloss black. Let me know if that changes anyone's order.
Rich
Mecho: 1 set in Red
Buteo: 1 set black
Joemat: 1 set black
jgarvish: 2 set red
Qship: 1 set black
Just in from Dan:
Rich
#40
