1st to 2nd upshift gear grind
I noticed that when I shift a little under 3000rpm from 1st to 2nd and make a pause in between shifting, since I'm breaking it in, I sometimes get a very mild grind/graunch noise. Has anyone noticed this? I did a search and can't find anything. Maybe I shouldn't baby it and just throw it right into 2nd. I'm just used to prior cars - m3 e93, evo x gsr, and rsx type s - that all liked to grind if you shifted too quickly up from 1 to 2.
I noticed that very occasionally during break-in and just chalked it up to releasing the clutch a little too quickly on those occasions, but I don't remember hearing it recently (I've got 3400 miles now), so maybe it was a break-in thing? Or maybe I'm just driving it better.
It's always cold in Alberta, but I try to run it above 6C. I think I'm just going to give it less pause between shifts and shift at higher revs, as I've only noticed it when I shift slow and at low revs.
Like everyone said easy when the gearbox is cold.
We used to have the problem with lotus. We cured it with a mixture of redline MT90 and GM synchromesh friction modifeyed fluid.
I originally found it from a Honda board they were notorious for bad syncros. Totally took away the grind when cold. Shinoo from sector111 now sells it . Carl
I have noticed it a couple times including once today. I'm at 325 miles of break-in. I thought I just wasn't being smooth enough which may have been the case as I was quick shifting from a light and enjoying the acceleration.
you should only need to pause as long as it takes the revs to drop so that the synchros have less work to do. If you pause too long, the synchros have more to do and when cold could cause the grinding effect.
This is what I've done for years with all of my cars when cold.Started doing it in 62 with my 56 Pontiac three on the tree... Works great.. Still use it with the GT4..
https://en.m.wikipedia.org/wiki/Doub...tch_(technique) Carl
