GT4 noise level, db
GT4 noise level, db
I know that the 991 GT3 is having some problems getting under the db noise level at some tracks, but how is the noise level for the GT4? Any experience with drive-by noise level, compared to the 991 GT3?
Thanks JB
Thanks JB
As others stated, the button doesn't matter at those RPMs. From what I'm told, a stock CS with PSE won't pass sound at Laguna without an redirect on the tips, so I can't imagine the GT4 could.
Not mine unfortunately. The exhaust was a custom arrangement by Mike Edwards Motorsport near London.
The owner tells me it reduced UK track static test (75% max revs tested at 45 degrees from exhaust outlet at 1 metre distance) to 92db from I guess 101/102db.
I run a 3.8L PDK Cayman with 200 cell headers (normally 101db static) and have found turndown tips helpful in reducing drive by noise as heard by detectors.
Considering a track day at Laguna Seca next month (have to decide quickly) and the sound requirements are always a pain. But it's a bucket list item to drive on that track.
Does anyone know how easy/hard it is to meet sound if you lift while passing the sound station? Seems like it might not be reliable.
Yes I was thinking about that too. Just not safe to lift unless everyone is on the same page.
It's not a major lift, it's a go to maintenance throttle lift. Most newer sports cars have to do this given the requirements. Everyone's usually really aware of the sound booth and since most track days are not races, it works out mostly.
