Heigo half cage
Then are the harnesses contacting the belt holes on the seat? Belt should pass freely without touching anything. It appears that for that bar to be at shoulder height, the belt would then contact the seat at the height the seat is set at there.
But you would know better if that is the case. It just looks like that to me in the picture.
Not the best. Tried to keep the camera out of the mirror. HTH
^ I see what you are saying. That means that the bar is indeed above your shoulder unfortunately. You can see that in the last pic of your original post.
Everyone will have to make their own judgment call as to whether that matters but Schroth doesn't recommend it.
GT3 player par excellence
looks nice.
and you all noticed GMG also has an offering.
i saw the one cantrell made, also beautiful. so now we have many choices
When I sit in the seat the top of my shoulders are just slightly above the bar separating the 2 feedthru holes in the seat. Therefore when I wear the belts they are not riding on that bar. The belts are 3" wide and therefore slightly touch the sides of those upper holes.
Really looks worse than it is IMHO. With this version you have the option of taking out the crossmembers if you choose.
