Front lip clearance?
My Targa GTS barely makes it into the garage without scraping its front lip. I measured the clearance at the very front and it's about 6.5 inches.
Could someone with a GT4 mind letting me know what their clearance is?
Thanks!
Thanks!
https://rennlist.com/forums/gt4/8797...opy-paste.html
...which says it's 11 cm / 4.33"
On the reversing in thing, my geometry skills are failing me and I can't quite think this through: would it make any difference? Meaning, wouldn't the front scrape on the way out instead of the way in? It might be easier to add some ramps for getting out.
I know some people will think this is dumb but how low the car is to the ground is definitely a significant downside to it. I live in Oakland and the roads are...well...like you'd probably imagine.
Thanks for the info.
I did look but didn't originally find one. However, suitably chastised by you ( ), I took another look and found this thread:
You'd be surprised though - of all the places that I drive, the only place that I scrape is on my driveway...
Bardman wanted me to tell you that someone did a CAD drawing that shows how that idea might function and posted it here on RL. HTH
As others have mentioned, it's the length of the overhang as well that's the issue. Height itself is meaningless.
If I recall the approach angle is 6 degrees. the official specs for height overhang and approach angle are posted somewhere in this forum if you can find it via search.
