P21s on Satin wheel finishes?
It might help fill the pores slightly but at end of day the wheels get hot and the wax doesnt help 100%. Personally i think waxing wheels is a waste of time.
I even use it on the windows and works better than Rain x.
You put 2 coats on the wheels and let it cure overnight and the brake dust mostly washes off with little effort.
I use a boar hair brush with rubber backing for the wheels.
I once washed my car (one wheel happened to be in the sun) and let the Sonax sit on one of the wheels for just a few minutes. It had dried and permanently marked the wheel. It only happened once since I made sure to clean one wheel at a time after that. Otherwise I love the product and it works great. I wouldn't want to be the first guinea pig on the new wheels.
I can't answer how it will do on the GT4's black wheels but just wanted to reiterate the warning on the bottle: DO NOT LET IT DRY ON THE WHEEL!!
Just curious, if not Sonax or P21s, what ARE people using to clean these wheels?
I may be missing something here, but are the black satin wheels simply painted and then clear coated, making them no different than a gray or silver painted wheel? Did they use a different coating process for the black wheels such as powder coating?
Great question.. The answer to that would determine how one should approach cleaning these black wheels.
Thanks... I was in the shade fortunately and let the Sonax sit for a couple minutes (it says on the back of the bottle, "let sit for 3-5 minutes") each wheel as I moved around the car. But didn't see any problems luckily.
Hit any leftover tar spots with Goo Gone.
Without knowing more about the wheel construction/finishing my 'hunch' is that any of the top-line non-acidic cleaners will be perfectly safe... As long as you follow the #1 golden rule for wheels which is only spray and clean one at a time, from start to finish. The only times I have ever gotten into trouble was when trying to cheat that rule and spraying one wheel with product to let it 'work' while cleaning another. It invariably gets problematic for me, whether it's wheel cleaner drying in the sun or simply not having the cleaner coating every inch of the wheel and working all the dirt... Which ONLY happens affectively when you move that product around with a brush (boars hair - perfect).
I don't believe in spray and walk away, because 1) it never seems to work for me. I always seem to end up re-spraying that wheel and cleaning it again; and 2) it just introduces unnecessary risk
